nRF24L01 Help Please. How to control relays/leds with joystick and add 1 button
Here is my current code that I saw on the internet and it works and I am now able to control 2 servos. Now I want to add another button to control a relay and another joystick (A2,A3) to control relays/led but I don't know how to code that, please help me.
Transmitter Code
#include <SPI.h>
#include "RF24.h"
RF24 radio(7, 8);
const uint64_t pipe = 0xE8E8F0F0E1LL;
int msg[1];
int potpin_1 = A0;
int val_1;
int potpin_2 = A1;
int val_2;
void setup(void) {
  pinMode(button, INPUT);
  radio.begin();
  radio.openWritingPipe(pipe);
  val_1 = analogRead(potpin_1), val_1 = map(val_1, 0, 1023, 0, 127), msg[0] = val_1, radio.write(msg, 1);
  val_2 = analogRead(potpin_2), val_2 = map(val_2, 0, 1023, 128, 255), msg[0] = val_2, radio.write(msg, 1);
Receiver Code
#include <Servo.h>
#include <SPI.h>
#include "RF24.h"
#define led 4
Servo servo1;
Servo servo2;
RF24 radio(7, 8);
int msg[1];
int data;
int pos;
  servo1.attach(3);
  servo2.attach(6);
  radio.begin();
  radio.openReadingPipe(1, pipe);
  radio.startListening();
  if (radio.available())radio.read(msg, 1);
  if (msg[0] < 128 && msg[0] > -1)data = msg[0], pos = map(data, 0, 127, 7, 177), servo1.write(pos);
  if (msg[0] > 127 && msg[0] < 255)data = msg[0], pos = map(data, 128, 254, 9, 177), servo2.write(pos);
The button is for turning on the relay when i pressed it. And when I push the joystick UP, it turns relay1, then DOWN turns relay 2, relay 3 for LEFT and relay4 for RIGHT
Delta_G:
I don't even know how you want them to work or what you want them to do.
Did you not think that might be important information?
Every Direction of the Joystick controls 1 relay, a total of 4 relays on the joystick then another one for the button
I would create a structure that holds joystick and button data and send the whole structure in one packet.
I dislike your misuse of the comma operator very much.
That only obfuscates and does not even spare characters to type.
The examples in this Simple nRF24L01+ Tutorial may help. Some of them send multiple values.
...R
Whandall:
Would you mind if you post the code here? Thanks
A sending sketch:
#include <RF24.h>
const uint8_t button = 2;
const uint8_t potpin_1 = A0;
const uint8_t potpin_2 = A1;
const uint8_t pipe[] = "apipe";
const uint16_t maxGapBetweenPackets = 100;
struct Packet {
  uint16_t pot1;
  uint16_t pot2;
  uint8_t key;
  bool getValues();
} data;
RF24 radio(7, 8);
void setup(void) {
  pinMode(button, INPUT_PULLUP);
  radio.begin();
  static uint32_t lastPacket;
  uint32_t topLoop = millis();
  if (data.getValues() || topLoop - lastPacket >= maxGapBetweenPackets) {
    radio.write(&data, sizeof(data));
    lastPacket = topLoop;
bool Packet::getValues() {
  bool same = true;
  uint16_t val = analogRead(potpin_1);
  if (val != pot1) {
    same = false;
    pot1 = val;
  val = analogRead(potpin_2);
  if (val != pot2) {
    same = false;
    pot2 = val;
  val = digitalRead(button);
  if (val != key) {
    same = false;
    key = val;
  return !same;
Whandall:
A sending sketch:
#include <RF24.h>
struct Packet {
  uint16_t pot1;
  uint16_t pot2;
  uint8_t key;
  bool getValues();
} data;
RF24 radio(7, 8);
void setup(void) {
  radio.begin();
  bool same = true;
  if (val != pot1) {
    same = false;
    pot1 = val;
  if (val != pot2) {
    same = false;
    pot2 = val;
  if (val != key) {
    same = false;
    key = val;
  return !same;
how about the receiver code?
How about using your own brain?
ibenzzz:
My tutorial has 3 sets of sending and receiving programs. Have you tried any of them?
...R
I have these 4 working codes for nrf24l01. 2 transmitter codes and 2 receiver codes. But I want to combine them but when I do, they do not work. Please help.
Combined Code RX
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include <Servo.h>
Servo FTHROWER;
Servo BLDC;
int DataMsg[1];
RF24 radio(7,8);
const uint64_t pipe = 0xE14BC8F482LL;
int Relay1 = 2;
int Relay2 = 3;
int data;
int pos;
  FTHROWER.attach(9);
  BLDC.attach(10);
  pinMode(Relay1, OUTPUT);
  pinMode(Relay2, OUTPUT);
  Serial.begin(57600);
  radio.begin();
  radio.openReadingPipe(1,pipe);
  digitalWrite(Relay1, HIGH);
  digitalWrite(Relay2, HIGH);
    bool done = false;
    while (!done)
radio.read(DataMsg, 1);
      Serial.print("NRF24L01 Receiver: ");
      Serial.println(DataMsg[0]);
      if (DataMsg[0] == 254)
        delay(10);
        digitalWrite(Relay1, LOW);
        digitalWrite(Relay2, HIGH );
      if (DataMsg[0] == 255)
        delay(10);
        digitalWrite(Relay2, LOW );
        digitalWrite(Relay1, HIGH );
      delay(100);
  Serial.println("Waiting for signal...");
radio.read(msg, 1);
if (DataMsg[0] <128 && DataMsg[0] >-1)data = DataMsg[0], pos = map(data, 0, 127, 7, 177),FTHROWER.write(pos);
if (DataMsg[0] >127 && DataMsg[0] <250)data = DataMsg[0], pos = map(data, 128, 250, 9, 177),BLDC.write(pos);
Combined Code TX
#include <SPI.h>
#include "RF24.h"
int DataMsg[1];
int potpin_1 = A0;
int val_1;
int potpin_2 = A1;
int val_2;
RF24 radio(7, 8);
int RVS = 4;
int FWARD = 5;
int LEFT = 2;
int RIGHT = 3;
int FTHROW = 6;
  //ativa pull-up
  pinMode(5, INPUT);
  digitalWrite(5, HIGH);
  pinMode(2, INPUT);
  digitalWrite(2, HIGH);
  pinMode(4, INPUT);
  digitalWrite(4, HIGH);
  pinMode(3, INPUT);
  digitalWrite(3, HIGH);
  pinMode(6, INPUT);
  digitalWrite(6, HIGH);
  Serial.println("NRF24L01 Transmitter");
  radio.begin();
  if (digitalRead(RIGHT) == LOW)
    Serial.println("RIGHT pressed");
DataMsg[0] = -2;
    radio.write(DataMsg, 1);
  if (digitalRead(LEFT) == LOW)
    Serial.println("LEFT Button pressed");
    DataMsg[0] = 2559;
  if (digitalRead(FWARD) == LOW)
    Serial.println("FORWARD pressed");
    DataMsg[0] = -3;
  if (digitalRead(RVS) == LOW)
    Serial.println("REVERSE pressed");
    DataMsg[0] = -5;
  if (digitalRead(FTHROW) == LOW)
    Serial.println("FTHROWER pressed");
    DataMsg[0] = -4;
  val_1 = analogRead(potpin_1), val_1 = map(val_1, 0, 1023, 0, 127), DataMsg[0] = val_1, radio.write(DataMsg, 1);
  val_2 = analogRead(potpin_2), val_2 = map(val_2, 0, 1023, 128, 250), DataMsg[0] = val_2, radio.write(DataMsg, 1);
The negative values send data to the receiver from 251 - 255. When I only use this:
It works well with controlling the servos but when I combine them with the working buttons code, only the buttons work and I lose control of the servos
Don't double Post. I have suggested to the Moderator to merge your Threads
...R
Robin2:
...R
I can't find you tutorial. May i have the link?
Simple rf24 tutorial by Robin2.
Whandall:
+1
ibenzzz:
I gave it to you in Reply #5 - it is very frustrating to give advice and have it completely ignored.
...R
@ibenzzz, please do not cross-post. Threads merged.
