NRF24L01 incorrect data[SOLVED]
This is part of an project I'm working on, I have an ESP32 with an rotary encoder sending the data to an Uno, But on the Uno side the part of the data is correct.
When I rotate the rotary endcoder on the EPS32 and this displays the correct values on the display and serial port monitor.
On first power up on the ESP32 the encoder value is 0 and the signal_good is 10 and these values are sent to the uno, On the uno through the serial monitor the encoder value is 0 (which is correct) but the Signal_good is 0, Which I thought should be 10 the same at the ESP32 is sending.
When I rotate the encoder in clockwise direction the uno displays the same value as the ESP32 and again in the anti-clockwise direction on the RotateCounter value .
But when the RotateCounter value goes below 0 the siganl_good show's a -1 and when the RotateCounter goes above 0 the signal_good show's 0 again and not 10.
Not sure whats going wrong am I missing something ?
This is the ESP32 code
//SLAVE mode
#include <Arduino.h>
#include <RF24Network.h>
#include <RF24.h>
#include <SPI.h>
#include "TFT_eSPI.h"
#include "U8g2_for_TFT_eSPI.h"
TFT_eSPI tft = TFT_eSPI();       // Invoke custom library
U8g2_for_TFT_eSPI u8f;       // U8g2 font instance
#include <TimedAction.h>
#include <Rotary.h>
#define ECHO_TO_SERIAL 1 //change to zero = no serial output
#define stepPin3 32                    // Set 'Step' rotary encoder pins
#define stepPin4 35
#define MoveSW 34  //SW pin on the rotary encoder (Button function)
RF24 radio(12, 14);            // nRF24L01 (CE,CSN)TEST
RF24Network network(radio);      // Include the radio in the network
const uint16_t this_node = 00;   // Address of our node in Octal format ( 04,031, etc)node00
const uint16_t Stepper_node = 03;   // Address of our node in Octal format ( 04,031, etc)node00
Rotary Volts_Rotary = Rotary(stepPin3, stepPin4);
int stepperRotarySteps; // This keeps track of the steps done with the rotary encoder
const byte Dac_multipliers[] = { 1, 2, 4, 6, 8 };
const byte stepCount = sizeof(Dac_multipliers) / sizeof(Dac_multipliers[0]);
volatile byte currentStep = 0;
typedef struct Motion_struct {
  int RotateCounter;
  int Siganl_good ;
  //boolean StepperData.Siganl_good;
} Motion_struct;
//Create a struct_message called  StepperData
Motion_struct StepperData;
//Print data to serail port
void printRecord(Print* pr, char sep = ',') {
  pr->print(StepperData.RotateCounter); // Print btye 7 Platform_Level
  pr->print(sep);
  pr->print(StepperData.Siganl_good);
  pr->println();
void TimerService02();
TimedAction Timedact02 = TimedAction(40, TimerService02); // mS
  tft.init();
  u8f.begin(tft);
  tft.setRotation(3);
  tft.fillScreen(TFT_BLACK);
  SPI.begin();
  radio.begin();
  network.begin(90, this_node);  //(channel, node address)
  radio.setDataRate(RF24_2MBPS);
  pinMode(MoveSW, INPUT_PULLUP); //added 10K resisotr
  pinMode(stepPin3, INPUT_PULLUP);     //added 10K resisotr
  pinMode(stepPin4, INPUT_PULLUP);//added 10K resisotr
  attachInterrupt(digitalPinToInterrupt(stepPin3), Volts_encoder, CHANGE);
  attachInterrupt(digitalPinToInterrupt(stepPin4), Volts_encoder, CHANGE);
  StepperData.RotateCounter = 0;
  // StepperData.Siganl_good = true;
  Buttons() ;
  network.update();
  //===== Sending =====//
  StepperData.Siganl_good = 10;
  RF24NetworkHeader header(Stepper_node);    // (Address where the data is going)
  bool ok = network.write(header, &StepperData, sizeof(StepperData) ); // Send the data
  Timedact02.check();
  // Timedact01.check();
void TimerService02() {
  u8f.setFontMode(0);
  u8f.setForegroundColor(TFT_WHITE);  // apply color// start writing at this position
  u8f.setFont(u8g2_font_inb27_mf);
  u8f.setCursor(10, 60);
  u8f.print(StepperData.RotateCounter);
  u8f.print(" ");
  u8f.setCursor(150, 60);
  u8f.print(Dac_multipliers[currentStep]);
#if ECHO_TO_SERIAL
  printRecord(&Serial);
#endif //ECHO_TO_SERIAL
void Volts_encoder()   {
  unsigned int result = Volts_Rotary.process();
  ///Rotary encoder 1 for setting the volts
  if (result) {
    if (result == DIR_CW) {
      StepperData.RotateCounter += Dac_multipliers[currentStep] ;
      StepperData.RotateCounter -= Dac_multipliers[currentStep] ;
void Buttons() {
#define buttonPressed LOW                             // When the button is pressed the input will be low, this is to remove the confusion this migth cause.
  uint32_t currentMillis = millis();                    // Millis times uses to debounce the button
  static uint32_t lastMillis;                           // Start of the debounce timeout
  const uint32_t BOUNCETIMEOUT = 20;                    // Debounce time in milliseconds
  bool currentButtonState = digitalRead(MoveSW);     // Reads the current state of the button and saves the result in a bool
  static bool lastButtonState;                          // Holds the previous debounced state of the button
  if (lastButtonState != currentButtonState) {          // Checks to see if the button has been pressed or released, at this point the button has not been debounced
    if (currentMillis - lastMillis >= BOUNCETIMEOUT) {  // Checks to see if the state of the button has been stable for at least bounceTimeout duration
      lastButtonState = currentButtonState;             // At this point the button has been debounced, so save the last state
      if (currentButtonState == buttonPressed) {
        currentStep++;
        if ( currentStep >= stepCount ) currentStep = 0;
        // The button might have been pressed or released, this make sure only presses are acted on, not releases
        Serial.print("MULTIPLIER SECLECTED BY :"); // Just added to see if there is any output on power up(DEBUGING ONLY)
        Serial.println(currentStep);//Dac_multipliers[]
        Serial.print("MULTIPLIER BY :"); // Just added to see if there is any output on power up(DEBUGING ONLY)
        Serial.println(Dac_multipliers[currentStep]);//Dac_multipliers[]
    lastMillis = currentMillis;                         // Saves the current value of millis in last millis so the debounce timer starts from current millis
and this is the Uno code:
//node 03
#include <RF24.h>
#include <SPI.h>
#define CE_PIN   7
#define CSN_PIN 10
RF24 radio (CE_PIN, CSN_PIN); // "myRadio" is the identifier you will use in following methods
const uint16_t this_node = 03;   // Address of this node in Octal format ( 04,031, etc)
boolean newData = true;
const long interval = 1500;
  int RotateCounter;
  int Siganl_good ;
} Motion_struct;
//Create a struct_message called myData
  pr->print(sep);
  pr->print(StepperData.Siganl_good); // Print btye 7 Platform_Level
  pr->print(sep);
  pr->print(newData); // Print btye 7 Platform_Level
  pr->println();
  SPI.begin();
  radio.begin();
  network.update();
  //===== Receiving =====//
  while ( network.available() ) {     // Is there any incoming data?
    RF24NetworkHeader header;
    network.read(header, &StepperData, sizeof(StepperData)); // Read the incoming data
#if ECHO_TO_SERIAL
and the Serial monitor from the uno
// postive direction, Ignoring the 1 at the end(not used yet).
7,0,1 // should be 7,10,1
// Negative direction
-7,-1,1 // should be -7,10,1
-7,-1,1 //should be -7,10,1
ESP32 output on serial monitor
// postive direction.
7,10
7,10
7,10
7,10
7,10
7,10
-7,10
-7,10
-7,10
-7,10
-7,10
-7,10
-7,10
int is a different thing on ESP32 and UNO.
Use int16_t (and attribute packed on the ESP32 side) or int32_t without on both sides.
structs are already types, why use a typedef?
Thanks Whandall,
That cured it and now works great, I never knew that int on ESP32 is different.
Not sure what you mean by this ?
why use a typedef?.
The way I've done it is how I've learnt from my meter project but that uses both pro mini's
That could be
  int16_t RotateCounter;
  int16_t Siganl_good;
} StepperData;
Whandall,
That makes sense now and I've just read up on typedef and I understand your way is easier and once again thank you for your help.
Steve
