NRF24L01 is not working even with a base module
Hello all
I´ve been working in a RC airplain controlled just by arduino, for this I used NRF24L01, but this results to be such a struggle 'cause it has had a lot of failures, bought a low signal antenna and a PNA one, with 2 base modules wich should work perfectly with 5V.
They worked perfectly the first days, but it didn't last ´cause when I tried it like at the 4 or 5 time it didn´t work at all, I reviewed the connections, also the script but nothing seems to be the problem, unfortunately I don´t have any multimeter or something like that to check some failure. Here I left the script if you want to look at it.
This is the reciever code:
#include <nRF24L01.h>
#include <SPI.h>
#include <RF24.h>
#include <RF24_config.h>
RF24 radio (7, 8);
const byte address[6] = "00001";
  radio.begin();
  radio.openReadingPipe(0, address);
  radio.setPALevel(RF24_PA_MIN);
  radio.startListening();
  if(radio.available()) {
    char text[32] = "";
    radio.read(&text, sizeof(text));
    Serial.println(text);
  else {
    const char text[] = "no funciona";
and this is the transmitter code
#include <SPI.h>
#include <RF24.h>
RF24 radio(7, 8);
  radio.begin();
  radio.openWritingPipe(address);
  radio.stopListening();
  const char text[] = "funciona!!!";
  radio.write(&text, sizeof(text));
It allways sends me to "no funciona" (it doesn´t work in spanish) when it shoud send "funcina!!"(it works!! in spanish), of course, it´s the proof code.
Hope you guys can help me with this, i've been trying and trying a long time ago, I'm really bored with this, and sorry for any english error, thank you.
Hello all
#include <SPI.h>
#include <RF24.h>
RF24 radio (7, 8);
  radio.begin();
    char text[32] = "";
  else {
#include <SPI.h>
#include <RF24.h>
RF24 radio(7, 8);
  radio.begin();
It allways sends me to "no funciona" (it doesn't work in spanish) when it shoud send "funcina!!"(it works!! in spanish), of course, it´s the proof code.
Have a look at this Simple nRF24L01+ Tutorial.
Wireless problems can be very difficult to debug so get the wireless part working on its own before you start adding any other features.
The examples are as simple as I could make them and they have worked for other Forum members. If you get stuck it will be easier to help with code that I am familiar with. Start by getting the first example to work.
Buy yourself a cheap digital multimeter.
...R
Three consecutive exclamation marks mean something special to the bootloader, so it is doubtful that your transmitter code ever got loaded into your Arduino.
There are tutorials and examples for the nRF24L01 but I don't have a link handy. Sorry!
Here is a link to Robin2's simple rf24 tutorial. I use this code for my radios and it works well.
@Jaspercat
DO NOT CROSS POST !
MULTIPLE other posts DELETED
It simply wastes peoples time and effort to help you and is against the rules of the forum.
Doing so again so many times like you did may lead to loss of forum privileges
READ THIS before posting any further.
Bob.
vaj4088:
yeah, could be true but, ¿does (") not explain to the chart it's just text?
Text is stored mostly "as is" in the program, so the entire piece of text including "!!!" gets passed to the bootloader. This has been a longstanding and probably undocumented issue with the bootloader, partly because it is not uncommon to use something like this when debugging.
Replace "!!!" with "!!" or "###" and this issue goes away.
