nRF24L01 + LNA + PA
hello,
I wanted to know if anyone has used the nRF24L01 + LNA + PA modules?
If this is the case could you tell me if it works with any type of Arduino?
Thank you
I have used it with the Uno and pro-mini, both worked well.
Hope this helps.
skywatch:
Hope this helps.
can u share a simple rx / tx comminucation code for nRF24L01+LNA+PA
Thanks..
Most probably it should have same code as the normal one. I will try it after finishing with ESP-01.
Anyone used it with Leonardo or micro or other 32u4 based arduinos?
