The set up is identical - I am swapping between the two with the same circuit - but the larger one works and the smaller one doesn't. I have the capacitor across pins 1 and 2 that everyone recommends. I have triple checked the pinout (and connections) as shown in the first link, and as far as I can see from following the traces, and using a multimeter, the pinout diagram is correct. I am completely stumped and don't even know how to start diagnosing what might be going wrong, given that everything at the MCU end is identical.
"Only need an external inductance when match antenna"
Now, I have no idea what that really means, but it may be that the smaller units can only talk to other smaller units unless you add inductance to match the antenna of the larger unit.
Totally guessing, you understand, but just thought it worth mentioning
Have you established communication with the module itself - that is, can you read back some of the module settings successfully?
I've tended to use the RF24 library which has a printDetails() function which reads the main module settings and prints them to the Serial output. Useful for making sure the Arduino can talk to the module OK...
howiem:
It's a bit trickier with the ATTINY84 but I think the next step must be to hook the new little units up to the Arduino Uno and see if I can do what you suggest. At least I can see whether the units themselves are working.
I suppose at a minimum you could just try setting the CRC value to something new, then try reading it back and flash an LED (or whatever) if all is OK...
howiem:
I’ve tended to use the RF24 library which has a printDetails() function which reads the main module settings and prints them to the Serial output. Useful for making sure the Arduino can talk to the module OK…
I’m trying to use the printDetails on the module which I know works, but I’m not getting anything out. I know that you have to include the printf which I’ve done, but do I need more? Here’s my code
Maybe we're using different RF24 libs then - so look what you have in the printf.h header and see if there is an initialisation function that needs to be called.
OK, I’ve tried something simpler - just trying to read something arbitrary - the PayLoadSize - from the nrf24l01. I’m getting a stream of “32” from it, which suggests that at least some communication is taking place. What next?
RogerRowland:
Maybe we’re using different RF24 libs then - so look what you have in the printf.h header and see if there is an initialisation function that needs to be called.
This is what’s in the printf.h that I have
Copyright (C) 2011 J. Coliz <maniacbug@ymail.com>
This program is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License
version 2 as published by the Free Software Foundation.
* @file printf.h
* Setup necessary to direct stdout to the Arduino Serial library, which
* enables 'printf'
#ifndef __PRINTF_H__
#define __PRINTF_H__
#ifdef ARDUINO
int serial_putc( char c, FILE * )
Serial.write( c );
return c;
void printf_begin(void)
fdevopen( &serial_putc, 0 );
#else
#error This example is only for use on Arduino.
#endif // ARDUINO
#endif // __PRINTF_H__
@file printf.h
enables ‘printf’
#ifndefPRINTF_H #definePRINTF_H
#ifdef ARDUINO
Serial.write( c );
Yes it's a Uno. The setup() is as posted above but with the addition of the printf_begin() that you suggested. (Sorry I would post it verbatim but have been kicked off the computer by Minecraft-addicted son.)
I wonder whether my printf.h is in the right folder? It's currently deep inside one of the RF24 examples folders - should it be somewhere else?
robertjenkins:
In all the RF24 examples, a copy of printf.h is in the folder containing the sketch. So, make sure you have a copy in your sketch too (it may be that the #include is resolving it elsewhere, which may explain the discrepancy).
I know from experience, that if you don't call printf_begin(), then you won't get any output from the radio.printDetails() call.
RogerRowland:
Damn I thought that (putting a copy of printf.h in the sketch folder) was going to work, but it doesn't.
Have you tried #include "printf.h"? The compiler looks in different places for the file with the quotes. I seem to remember that that helped when I had trouble with the rf24 lib.
Tried something else - a call to isPVariant() which apparently tells whether the hardware is an nRF24L01+ or not. It says it is ...
Also, out of the blue, and for the first time, the unit managed to transmit a single digit, which is sort of promising, though it hasn't happened again.
