nRF24L01+ Module with the RF24Mesh Library - Char Array Receiving Problem
I am using the nRF24L01+ module with the RF24Mesh library. I am able to transmit the data I want except for one character. Obviously, I am missing something but I can’t figure out what. Can you please help me?
Here is the problem
I transmit:
2
5
1.00
2.00
3.00
4.00
2017-09-06 01:02:03
and I receive:
2
5
1.00
2.00
3.00
4.00
⸮017-09-06 01:02:03
I am getting instead of 2.
Here is the abbreviated version of the transmitter code:
/*** Tx ***/
#include <RF24.h>
#include <RF24Network.h>
#include <RF24Mesh.h>
#include <SPI.h>
#include "printf.h"
RF24 radio(9, 10); //Nano
RF24Network network(radio);
RF24Mesh mesh(radio, network);
long previousMillis = 0;
long interval = 30000;
struct payload_t
  int node;
  float v1;
  float v2;
  float v3;
  float v4;
  char dt[20];
int node_;
float v1_;
float v2_;
float v3_;
float v4_;
char dt_[20];
void setPayloadValues()
  node_ = 2;
  v1_ = 1.00;
  v2_ = 2.00;
  v3_ = 3.00;
  v4_ = 4.00;
  String sdt = "2017-09-06 01:02:03";
  sdt.toCharArray(dt_, sdt.length() + 1);
  printf_begin();
  mesh.setNodeID(2);
  mesh.begin(97, RF24_250KBPS, 60000);
  radio.printDetails();
  if (currentMillis - previousMillis > interval)
    setPayloadValues();
    payload_t payload = {node_, v1_, v2_, v3_, v4_, strcpy(payload.dt, dt_)};
    if (!mesh.write(&payload, 'M', sizeof(payload)))
      //Problem
and this is the receiver
/*** Rx ***/
#include <RF24.h>
#include <SPI.h>
#include <EEPROM.h>
#include "printf.h"
struct payload_t
  int node;
  float v1;
  float v2;
  float v3;
  float v4;
  char dt[20];
  printf_begin();
  mesh.setNodeID(0);
  mesh.update();
  mesh.DHCP();
  if (network.available()) {
    RF24NetworkHeader header;
    network.peek(header);
    payload_t payload;
    switch (header.type) {
      case 'M':
        network.read(header, &payload, sizeof(payload));
        Serial.println(String(payload.node));
        Serial.println(String(header.from_node));
        Serial.println(String(payload.v1));
        Serial.println(String(payload.v2));
        Serial.println(String(payload.v3));
        Serial.println(String(payload.v4));
        Serial.println(payload.dt);
      default:
        network.read(header, 0, 0);
        Serial.println(header.type);
Do you REALLY believe that the println() function doesn't know how to print an int without your "help" converting it to a string embedded in a String?
The second argument to toCharArray() is NOT the amount of data to extract. It is the size of the array to copy do.
Of course, there was NO reason to store the string in a String in the first place.
You are trying to create an initialize an instance of a struct, populating it with an element of the struct being created. Why?
    payload_t payload = {node_, v1_, v2_, v3_, v4_, ""};
    strcpy(payload.dt, dt_);
@PaulS,
Thank you for your reply. Obviously, I don't know what I am doing. Even though your insight is greatly appreciated you still did not answer the original question, I am correct?
No problem, I did find an answer, I'll be posting a solution to the problem later today.
Thank you,
