NRF24L01 Network
I'm doing weather stations, for demo i do 3layer like this
*| | 00 | Master Node (00)
*| | | 01 | 02 | 1st level children of master (00)
*| |011| 2nd level children of master. Children of 1st level.
Node 011: temperature, humidity sensors
Node 01 : as a router forward package from node011 to node00 (assum that node011 too far away
from node00)
Node 02 :temperature, humidity sensors
I've succeed with 2 layer node00, node01, node02. Here is what is found but dont really understand. Have anyone done with Rf24network, could you give me some tips for my project.
  • When sending a message using RF24Network::write(), you fill in the header with the logical
  • node address. The network layer figures out the right path to find that node, and sends
  • it through the system until it gets to the right place. This works even if the two nodes
  • are far separated, as it will send the message down to the base node, and then back out
  • to the final destination.
My TX code for 2 layer
#include <SPI.h>
#include <RF24Network.h>
#include <RF24Network_config.h>
#include <Sync.h>
#include <nRF24L01.h>
#include <printf.h>
#include <RF24.h>
#include <RF24_config.h>
  struct package0
    float temperature = 0;
    float humidity = 0;
    int soil = 0;
  typedef struct package0 Package0;
  Package0 pack0;
  struct package1
    float humidity = 0;
    int soil = 0;
  typedef struct package1 Package1;
  Package1 pack1;
/******************RF24******************/
  RF24 radio(25,26);
  RF24Network network(radio);
  const uint16_t this_node = 00; //Octal format
  const uint16_t node01 = 01;
  const uint16_t node02 = 02;
  const uint16_t node011 = 011;
  SPI.begin();
  WiFi_init();
  radio.begin();
  network.begin(90, this_node);
  radio.setPALevel(RF24_PA_MIN);
  radio.setDataRate(RF24_250KBPS);
  network.update();
  if(network.available())
    RF24NetworkHeader header;
    network.read(header, &pack0, sizeof(pack0));
    if (header.from_node == 1)
      Serial.print("From node0");
      Serial.println(header.from_node);
      Serial.print(pack0.temperature);
      Serial.println("C");
      Serial.print(pack0.humidity);
      Serial.println("%");
      Serial.print(pack0.soil);
    else if (header.from_node == 2)
      pack1.temperature = pack0.temperature;
      pack1.humidity = pack0.humidity;
      pack1.soil= pack0.soil;
My TX code
#include <DHT.h>
#include <SPI.h>
#include <printf.h>
#include <RF24.h>
#include <Sync.h>
/**************soil***************/
  int SOILPIN = 36;
/***************DHT***************/
  #define DHTPIN 2
  #define DHTTYPE DHT11
  DHT dht(DHTPIN, DHTTYPE);
  float temperature_old = 0;
  float humidity_old = 0;
  int soil_old = 0;
  struct package0
    float humidity = 0;
    int soil = 0;
  Package0 pack0;
/**************RF24****************/
  RF24 radio(25,26);
  const uint16_t this_node = 01;
  const uint16_t master00 = 00;
  pinMode(SOILPIN, INPUT);
  dht.begin();
  radio.begin();
  network.update();
  readdht();
void readdht()
  delay(2000);
  pack0.humidity = dht.readHumidity();
  pack0.temperature = dht.readTemperature();
  pack0.soil = map(analogRead(SOILPIN), 0, 4096, 100, 0);//convert to percentage
  if (isnan(pack0.humidity) || isnan(pack0.temperature))
    Serial.println(F("Failed to read from DHT sensor!"));
    return;
  RF24NetworkHeader header(master00);
  bool ok = network.write(header, &pack0, sizeof(pack0));
for 3 layers, from what i understand
For node011, just use
am i correct? i dont see what is difference with the code i use, and node011 dont have any reference with node01
First question - how far apart are the nRF24 / Arduino devices? Maybe there is no need to use the Network system. If you don't need it then life will be simpler.
...R
Simple nRF24L01+ Tutorial
Don't DOUBLE POST! I have already replied to your other Thread.
I am suggesting to the Moderator to merge them.
...R
Threads merged.
Robin2:
...R
For this project, i want to demo a network system, so it's possible deploy in a large area. 2 layers (node 00; node01, node02) is ok, but i have problems for more layer here.
Do you have experence in RF24Network library?
thanks for replying
mixaobo123451211:
That is very reasonable
No. All of my projects have been close range.
...R
