Since the past few days I've been trying to get two of my nrf24l01 modules to communicate with each other without any progress. I would greatly appreciate any help provided on this forum. Thank you for your time.
I have two nrf24l01 modules (which I bought from here: https://robu.in/product/2-4ghz-nrf24l01palna-sma-antenna-wireless-transceiver-communication-module-1km/) and two arduino nanos. Additionally, I'm using two AMS1117 3.3 V regulators which are fed 5V from my nano. The 3.3V outputs are then given to my radio modules.
I attached my radio module on a breadboard using a simple adapter I made. Then, the connections I made were as follows:
MOSI - D11
MISO - D12 (I also entangled MISO and MOSI wires)
SCK - D13
GND - GND
VCC - 3.3V from AMS
CE - D9
CSN - D10
I've also put a 10uf capacitor between each radio module's GND and VCC.
After all of this, when I ran radio.printdetails(), I got the following output for both radio modules:
SPI Speedz = 10 Mhz
STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
RX_ADDR_P0-1 = 0x65646f4e31 0x65646f4e32
RX_ADDR_P2-5 = 0xc3 0xc4 0xc5 0xc6
TX_ADDR = 0x65646f4e31
RX_PW_P0-6 = 0x20 0x20 0x20 0x20 0x20 0x20
EN_AA = 0x3f
EN_RXADDR = 0x02
RF_CH = 0x4c
RF_SETUP = 0x03
Finally, once I was sure about the hardware setup, I tried using the following code suggested at Simple nRF24L01+ 2.4GHz transceiver demo
// SimpleTx - the master or the transmitter
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 10
const byte slaveAddress[5] = {'R','x','A','A','A'};
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
char dataToSend[10] = "Message 0";
char txNum = '0';
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 1000; // send once per second
Serial.println("SimpleTx Starting");
radio.begin();
radio.setDataRate( RF24_250KBPS );
radio.setRetries(3,5); // delay, count
radio.openWritingPipe(slaveAddress);
currentMillis = millis();
if (currentMillis - prevMillis >= txIntervalMillis) {
send();
prevMillis = millis();
void send() {
bool rslt;
rslt = radio.write( &dataToSend, sizeof(dataToSend) );
// Always use sizeof() as it gives the size as the number of bytes.
// For example if dataToSend was an int sizeof() would correctly return 2
Serial.print("Data Sent ");
Serial.print(dataToSend);
if (rslt) {
Serial.println(" Acknowledge received");
updateMessage();
else {
Serial.println(" Tx failed");
void updateMessage() {
// so you can see that new data is being sent
txNum += 1;
if (txNum > '9') {
txNum = '0';
dataToSend[8] = txNum;
// SimpleRx - the slave or the receiver
#include <SPI.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 10
const byte thisSlaveAddress[5] = {'R','x','A','A','A'};
char dataReceived[10]; // this must match dataToSend in the TX
bool newData = false;
Serial.println("SimpleRx Starting");
radio.begin();
radio.openReadingPipe(1, thisSlaveAddress);
radio.startListening();
getData();
showData();
void getData() {
if ( radio.available() ) {
radio.read( &dataReceived, sizeof(dataReceived) );
newData = true;
void showData() {
if (newData == true) {
Serial.print("Data received ");
Serial.println(dataReceived);
newData = false;
And on the transmitter side I got Tx failed and on the receiver side I got nothing displayed on the Serial monitor.
I would greatly appreciate it if you could help me solve my problem corresponding to these radio modules. I thank you again for your time and effort.
