nRF24L01 not working with arduino uno
Hello everyone,
I have been trying to make a arduino leonardo wireless gamecontroller with nRF24L01, so I tried to make a simple transmitter that sends hello world! to the serial moniter with 2 arduino unos. So I first tried this code and it worked:
transmitter
* Arduino Wireless Communication Tutorial
*     Example 1 - Transmitter Code
* by Dejan Nedelkovski, www.HowToMechatronics.com
* Library: TMRh20/RF24, https://github.com/tmrh20/RF24/
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(7, 8); // CE, CSN
const byte address[6] = "00001";
  radio.begin();
  radio.openWritingPipe(address);
  radio.setPALevel(RF24_PA_MIN);
  radio.stopListening();
  const char text[] = "Hello World";
  radio.write(&text, sizeof(text));
reciever:
*       Example 1 - Receiver Code
#include <SPI.h>
#include <RF24.h>
  radio.begin();
  radio.openReadingPipe(0, address);
  radio.startListening();
  if (radio.available()) {
    char text[32] = "";
    radio.read(&text, sizeof(text));
    Serial.println(text);
Then I tried to add a button on the transmitter and when I press it turns on a led on the reciever. I got the code from a youtuber called howtomechatronics but it didn't work. I tried it multiple times but it is still not working. The code for reciever and transmitter is:
transmitter:
*     Example 2 - Transmitter Code
#include <SPI.h>
#include <RF24.h>
#define led 12
const byte addresses[][6] = {"00001", "00002"};
boolean buttonState = 0;
  pinMode(12, OUTPUT);
  radio.begin();
  radio.openWritingPipe(addresses[1]); // 00002
  radio.openReadingPipe(1, addresses[0]); // 00001
  delay(5);
  int potValue = analogRead(A0);
  int angleValue = map(potValue, 0, 1023, 0, 180);
  radio.write(&angleValue, sizeof(angleValue));
  delay(5);
  while (!radio.available());
  radio.read(&buttonState, sizeof(buttonState));
  if (buttonState == HIGH) {
    digitalWrite(led, HIGH);
  else {
    digitalWrite(led, LOW);
receiver :
*     Example 2 - Receiver Code
#include <SPI.h>
#include <RF24.h>
#include <Servo.h>
#define button 4
Servo myServo;
  pinMode(button, INPUT);
  myServo.attach(5);
  radio.begin();
  radio.openWritingPipe(addresses[0]); // 00001
  radio.openReadingPipe(1, addresses[1]); // 00002
  delay(5);
  if ( radio.available()) {
    while (radio.available()) {
      int angleV = 0;
      radio.read(&angleV, sizeof(angleV));
      myServo.write(angleV);
    delay(5);
    buttonState = digitalRead(button);
    radio.write(&buttonState, sizeof(buttonState));
Can anyone tell me why it is not working and also can anyone link me to working tutorials.
Have a look at this Simple nRF24L01+ Tutorial.
Wireless problems can be very difficult to debug so get the wireless part working on its own before you start adding any other features.
The examples are as simple as I could make them and they have worked for other Forum members. If you get stuck it will be easier to help with code that I am familiar with. Start by getting the first example to work
There is also a connection test program to check that the Arduino can talk to the nRF24 it is connected to.
A common problem with nRF24 modules is insufficient 3.3v current from the Arduino 3.3v pin. This seems to be a particular problem with the nano. The high-power nRF24s (with the external antenna) will definitely need an external power supply. At least for testing try powering the nRF24 with a pair of AA alkaline cells (3v) with the battery GND connected to the Arduino GND.
If you are using the high-power nRF24s (with the external antenna) make sure there is sufficient distance between the two nRF24s so that the signal does not overwhelm the receiver - try 3 metres separation. If you are new to nRF24s it may be better to start with a pair of low power modules with the pcb antenna.
...R
Would seem a lot easier to start by taking your working RF24 code (Example 1) and adding a button send.
Is the addition of the servo (Example 2) part of your design, or something just copied and pasted from the tutorials?
Hello guys,
The second code is now workings guys, thank you for you help.
Thank you
