hi, I use 3 sets of nrf24l01+ and arduino uno.
One as base station and the others are nodes.
First, the base station send a broadcast (multicast) to pipe1, and then listen on pipe2 to wait for reply.
The others act as nodes listen on pipe 1 and if radio available, send a reply to pipe2.
My problem is, if I use only two, one as base station and one as node, it works charming.
When I add a node into (become 1 base and 2 nodes), just one of nodes acts.
The other node listening nothing and no reply.
If I reset the idle node, it act as what I want and base station received 2 reply as charming.
But just that round is normal, next round receive only one node reply.
I use RF24 (maniacbug and tmrh20) library and arduino uno, code is as below, please help me, Thanks.
Copyright (C) 2011 James Coliz, Jr. <maniacbug@ymail.com>
This program is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License
version 2 as published by the Free Software Foundation.
* Example RF Radio Ping Pair
* This is an example of how to use the RF24 class. Write this sketch to two different nodes,
* connect the role_pin to ground on one. The ping node sends the current time to the pong node,
* which responds by sending the value back. The ping node can then see how long the whole cycle
* took.
#include <SPI.h>
#include "nRF24L01.h"
#include <RF24.h>
#include "printf.h"
// Hardware configuration
// Set up nRF24L01 radio on SPI bus plus pins 8 & 9
RF24 radio(9, 10);
// sets the role of this unit in hardware. Connect to GND to be the 'pong' receiver
// Leave open to be the 'ping' transmitter
const int role_pin = 7;
// Topology
// Radio pipe addresses for the 2 nodes to communicate.
const uint64_t pipes[2] = { 0xABCDABCDE1LL, 0xABCDABCDD2LL };
// Role management
// Set up role. This sketch uses the same software for all the nodes
// in this system. Doing so greatly simplifies testing. The hardware itself specifies
// which node it is.
// This is done through the role_pin
// The various roles supported by this sketch
typedef enum { role_ping_out = 1, role_pong_back } role_e;
// The debug-friendly names of those roles
const char* role_friendly_name[] = { "invalid", "Ping out", "Pong back"};
// The role of the current running sketch
role_e role;
void setup(void)
// Role
// set up the role pin
pinMode(role_pin, INPUT);
digitalWrite(role_pin,HIGH);
delay(20); // Just to get a solid reading on the role pin
// read the address pin, establish our role
if ( ! digitalRead(role_pin) )
role = role_ping_out;
role = role_pong_back;
// Print preamble
Serial.begin(57600);
printf_begin();
printf("\n\rRF24/examples/pingpair/\n\r");
printf("ROLE: %s\n\r",role_friendly_name[role]);
// Setup and configure rf radio
radio.begin();
// optionally, increase the delay between retries & # of retries
// radio.setRetries(15,15);
// optionally, reduce the payload size. seems to
// improve reliability
// radio.setPayloadSize(8);
// Open pipes to other nodes for communication
// This simple sketch opens two pipes for these two nodes to communicate
// back and forth.
// Open 'our' pipe for writing
// Open the 'other' pipe for reading, in position #1 (we can have up to 5 pipes open for reading)
if ( role == role_ping_out )
radio.openWritingPipe(pipes[0]);
radio.openReadingPipe(1,pipes[1]);
radio.openWritingPipe(pipes[1]);
radio.openReadingPipe(1,pipes[0]);
// Start listening
// if( radio.setDataRate( RF24_250KBPS ) ) {
// printf( "Data rate 250KBPS set!\n\r" ) ;
// } else {
// printf( "Data rate 250KBPS set FAILED!!\n\r" ) ;
// radio.setDataRate( RF24_2MBPS ) ;
// radio.setPALevel( RF24_PA_MAX ) ;
radio.enableDynamicPayloads() ;
//radio.setAutoAck( false ) ;
//radio.powerUp() ;
radio.startListening();
// Dump the configuration of the rf unit for debugging
radio.printDetails();
char sendBuffer[33];
uint8_t counter = 1;
void loop(void)
// Ping out role. Repeatedly send the current time
if (role == role_ping_out)
// send it. This will block until complete
sprintf(sendBuffer, "%d|root", counter);
// First, stop listening so we can talk.
radio.stopListening();
printf("Now sending %s...", sendBuffer);
bool ok = radio.write( sendBuffer, strlen(sendBuffer), true );
if (ok) printf("ok...\r\n");
else printf("no ack, failed...\r\n");
counter++;
// wait for reply
unsigned long time_started_waiting = millis();
uint8_t pipe_num;
bool timeout = false;
while( !timeout ) {
if (radio.available(&pipe_num)) {
uint8_t len = radio.getDynamicPayloadSize();
char backPayload[33];
radio.read( backPayload, len );
backPayload[len] = 0;
printf("Got reply \"%s\" from pipe \"%d\".\r\n", backPayload, pipe_num);
if ( (millis() - time_started_waiting) > 3000 ) {
timeout = true;
printf("This round is over.\r\n\r\n");
// Try again 1s later
// Pong back role. Receive each packet, dump it out, and send it back
if ( role == role_pong_back )
uint8_t pipe_num;
//printf("counter = %d\r\n", counter);
// if there is data ready
if ( radio.available(&pipe_num) && pipe_num == 1)
// Dump the payloads until we've gotten everything
char receivePayload[33];
bool done = false;
while (radio.available())
// Fetch the payload, and see if this was the last one.
radio.read( receivePayload, len );
receivePayload[len] = 0;
printf("received pipe: %d, \"%s\".\n\r", pipe_num, receivePayload);
strcat(receivePayload, "|node2");
delay(random(10, 20)*3);
radio.write(receivePayload, strlen(receivePayload), true);
