Hello all,
I am relatively new to Arduino and programming. I have successfully connected my RPi and Arduino Nano (clone) with two nRF24l01+. I am working on a home automation project and would like to switch on/off a few delays on Arduino. I am now introducing and second Arduino Nano (clone) with the third nRF24l01+. The idea is as follows. Either my RPi is going to broadcast it to both Arduinos or RPi is going to talk to each Arduino separately (is it possible?). I have been struggling with the code. This is either only one of two Arduinos (nodes) working or none. All the wiring is correct and has been double checked (the code below works on both Arduinos).
Here is the original code I have used communicating RPi-Arduino
This program is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License
version 2 as published by the Free Software Foundation.
Hack.lenotta.com
Modified code of Getting Started RF24 Library
It will switch a relay on if receive a message with text 1,
turn it off otherwise.
Edo
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include "printf.h"
int relay1 = 8;
int relay2 = 7;
// Hardware conf
// Set up nRF24L01 radio on SPI bus plus pins 9 & 10
RF24 radio(9, 10);
bool radioNumber = 0;
// Topology
// Radio pipe addresses for the 2 nodes to communicate.
//const uint64_t pipes[2] = { 0x65646f4e32, 0x65646f4e31 };
//const uint64_t pipes[2] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0D2LL };
const uint8_t pipes[][6] = {"1Node", "2Node"};
char * convertNumberIntoArray(unsigned short number, unsigned short length) {
char * arr = (char *) malloc(length * sizeof(char)), * curr = arr;
do {
*curr++ = number % 10;
number /= 10;
} while (number != 0);
return arr;
unsigned short getId(char * rawMessage, unsigned short length) {
unsigned short i = 0;
unsigned short id = 0;
for ( i = 1; i < length; i++) {
id += rawMessage[i] * pow( 10, i - 1 );
return id;
unsigned short getMessage( char * rawMessage) {
unsigned short message = rawMessage[0];
return (unsigned short)message;
unsigned short getLength( unsigned int rudeMessage) {
unsigned short length = (unsigned short)(log10((float)rudeMessage)) + 1;
return length;
void setup(void)
// Print preamble
Serial.begin(57600);
pinMode(relay1, OUTPUT);
digitalWrite(relay1, HIGH);
pinMode(relay2, OUTPUT);
digitalWrite(relay2, HIGH);
printf_begin();
printf("\nRemote Switch Arduino\n\r");
// Setup and configure rf radio
radio.begin();
radio.setAutoAck(1); // Ensure autoACK is enabled
radio.setRetries(15, 15);
radio.openWritingPipe(pipes[1]);
radio.openReadingPipe(1, pipes[0]);
radio.startListening();
radio.printDetails();
int getState(unsigned short pin) {
boolean state = digitalRead(pin);
return state == true ? 0 : 1;
void doAction(unsigned short id, unsigned short action) {
if ( action == 0 ) {
digitalWrite(id, HIGH);
} else if (id == 7) {
digitalWrite(id, LOW);
delay (200);
digitalWrite(id,LOW);
void sendCallback(unsigned short callback) {
// First, stop listening so we can talk
radio.stopListening();
// Send the final one back.
radio.write( &callback, sizeof(unsigned short) );
printf("Sent response.\n\r");
// Now, resume listening so we catch the next packets.
void performAction(unsigned short rawMessage) {
unsigned short action, id, length, callback;
char * castedMessage;
length = getLength(rawMessage);
castedMessage = convertNumberIntoArray(rawMessage, length);
action = getMessage(castedMessage);
id = getId(castedMessage, length);
if (action == 0 || action == 1) {
callback = action;
doAction(id, action);
} else if (action == 2) {
callback = getState(id);
sendCallback(callback);
void loop(void)
// if there is data ready
if ( radio.available() )
// Dump the payloads until we've gotten everything
unsigned short message;
bool done;
// char * new;
unsigned short rawMessage;
done = false;
while ( radio.available() )
// Fetch the payload, and see if this was the last one.
radio.read( &rawMessage, sizeof(unsigned long) );
// Spew it
printf("Got message %d...", rawMessage);
performAction(rawMessage);
delay(10);
Ideally, I would like to utilise the same pins on Arduinos so I need the RPi to talk to each Arduino individually. I also understand that if I want to broadcast, I need to use
radio.enableDynamicPayloads() ;
radio.enableDynamicAck();
//radio.setAutoAck( false ) ;
However, if I insert the above code, the communication stops.
I am using the latest TMRh20 library on all Arduinos and RPi.
Your help is highly appreciated.
