nrf24l01+pa+lna not connecting to each other, and not lighting a LED up
So, i was trying to get two nrf24l01+pa+lna to connect to each other with arduino uno and when they connect a LED should light up, But for some reason they wont connect. Like nothing happens at all
This is the transmitter code and the wiring:
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(7, 8); // CE, CSN
const byte address[5] = "00001";
  radio.begin();
  radio.openWritingPipe(address);
  radio.setPALevel(RF24_PA_MIN);
  radio.stopListening();
  const char text[] = "YEET";
  radio.write(&text, sizeof(text));
And this is the wiring for it:
BASE MODULE ARDUINO
VCC 5V
GND GND
CD PIN 7
CSN PIN 8
SCK PIN 13
MO PIN 11
M1 PIN 12
IRQ NO CONNECT
and this is the code for the reciever:
#include <printf.h>
#include <RF24.h>
#include <RF24_config.h>
RF24 radio(7,8);
void setup(){
  pinMode(2, OUTPUT);
  radio.begin();
  radio.openReadingPipe(0,address);
  radio.setPALevel(RF24_PA_MAX);
  radio.setDataRate(RF24_250KBPS);
  radio.startListening();
void loop(){
  char text[3] = "";
  if (radio.available()){
    radio.read(&text, sizeof(text));
    String transData = String(text);
    if (transData == "YEET"){
      digitalWrite(2, HIGH);
    } else{
      digitalWrite(2, LOW);
And here’s the wiring for the receiver:
BASE MODULE ARDUINO
VCC 5V
GND GND
CD PIN 7
CSN PIN 8
SCK PIN 13
MO PIN 11
M1 PIN 12
IRQ NO CONNECT
but there’s also a LED and that one is:
LED+ PIN 2
LED- GND
there’s also a ohm resistor between LED- and GND the colour pattern is: red, red, black, black, red
If you need anymore info just ask.
Have a look at this Simple nRF24L01+ Tutorial.
Wireless problems can be very difficult to debug so get the wireless part working on its own before you start adding any other features.
The examples are as simple as I could make them and they have worked for other Forum members. If you get stuck it will be easier to help with code that I am familiar with. Start by getting the first example to work
There is also a connection test program to check that the Arduino can talk to the nRF24 it is connected to.
A common problem with nRF24 modules is insufficient 3.3v current from the Arduino 3.3v pin. This seems to be a particular problem with the nano. The high-power nRF24s (with the external antenna) will definitely need an external power supply. At least for testing try powering the nRF24 with a pair of AA alkaline cells (3v) with the battery GND connected to the Arduino GND.
If you have a pair of the low-power nRF24s (with the PCB antenna) it would be a good idea to get the system working with them first. The code for the high-power modules will be identical.
...R
also make text bigger and print it out directly in the receiver part to see what it looks like.
char text[3] = "";    // this is probably overflowing
if (transData == "YEET"){   // this looks bigger than text, from which it is derived, could hold
The nRF24L01 modules run off 3.3V. From your connection description it looks like you’ve connected the module to 5V.
Robin2: Have a look at this Simple nRF24L01+ Tutorial.
...R
i wanna say thank you for helping me, your tutorial really helped in one go, and i wanna thank you again for the help
markd833: The nRF24L01 modules run off 3.3V. From your connection description it looks like you've connected the module to 5V.
i also wanna say thank you for the idea i switched the 5v to the 3.3v pin and with robin's tutorial it really helped
