NRF24l01 + PA + LNA not workig !
Hey ...
So ... i'm trying to make a radio control receiver & transmitter ... I have no problem using NRF24L01 but when I try to use the NRF24l01 + PA + LNA I don't get any results ... they kinda are the same thing ... right ??
I've been using 2 NRF24l01 modules and now I'm trying to use 2 NRF24l01+ modules ... but tey don't work ... is there any difference between these two ??
You have provided almost no information with which to help you - no programs and no wiring diagrams.
Have a look at this Simple nRF24L01+ Tutorial.
Wireless problems can be very difficult to debug so get the wireless part working on its own before you start adding any other features.
The examples are as simple as I could make them and they have worked for other Forum members. If you get stuck it will be easier to help with code that I am familiar with. Start by getting the first example to work
There is also a connection test program to check that the Arduino can talk to the nRF24 it is connected to.
A common problem with nRF24 modules is insufficient 3.3v current from the Arduino 3.3v pin. The high-power nRF24s (with the external antenna) will definitely need an external power supply. At least for testing try powering the nRF24 with a pair of AA alkaline cells (3v) with the battery GND connected to the Arduino GND.
Also, it seems to be important not to have a high-power module too close to the other module - try having them 3 metres apart.
...R
soroush2000:
Hey ...
A good place to start when using any of the NRF24 range is to use the adaptor module.
It avoids many problems.
