I have 2 NRF24L01 units connected to 2 UNO's, they communicate perfectly when I have them both set to LOW power mode but don't communicate when I have them both set to HIGH power mode. I have each NRF24L01 powered from its own 850mA single cell LIPO. The NRF24L01 units are about 1 meter apart. Is the signal too strong when that close? I would like to use HIGH power mode as one unit is a base unit and the other is a handheld device, the system works perfectly up to about 15 meters, would like to use HIGH power mode to extend the range a bit.
It can easily happen that a receiver front end can receive too much power if the boards are close. I don't know about the NRF24L01, but many times I have sat and cussed at a couple of transceivers on my lab bench, only to find they worked fine at a greater distance.
radio.begin();
// Set the PA Level low to prevent power supply related issues since this is a
// getting_started sketch, and the likelihood of close proximity of the devices. RF24_PA_MAX is default.
radio.setPALevel(RF24_PA_LOW);
extending range might be more about good antenna, reasonable data rate (RF24_250KBPS) and clean power supply rather than pure power. As this is also using the same band as wifi networks, a scan of how busy channels are in your area would help select one with less noise. I've a unit on top of a tree about 600m away from my home and getting loud and clear signal back - so it's doable.
There are various modules with different capabilities, see https://arduino-info.wikispaces.com/Nrf24L01-2.4GHz-HowTo#lib and the discussion about Range
