# nrf24L01+ power setting question
**URL:** <https://forum.arduino.cc/t/nrf24l01-power-setting-question/518289>\
**Category:** Networking, Protocols, and Devices\
**Created:** [April 4, 2018, 12:34pm UTC](https://forum.arduino.cc/t/nrf24l01-power-setting-question/518289 "2018-04-04T12:34:24Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![stevef](https://avatars.discourse-cdn.com/v4/letter/s/f17d59/32.png) [@stevef](https://forum.arduino.cc/u/stevef)\
**Post date:** [April 4, 2018, 12:34pm UTC](https://forum.arduino.cc/t/nrf24l01-power-setting-question/518289/1 "2018-04-04T12:34:24Z")
</div>
I am using a nrf24l01+ with the PA and external antenna and have success in transmitting and receiving data over quite large distances and through walls.
My question is regarding the PA\_MIN / PA\_LOW / PA\_HIGH and PA\_MAX settings.
I am only transmitting one way as far as the data is concerned and as the amount of data is minimal, I only have the data rate at 250KBPS.
I have been range testing and with several different physical modules and arduinos i get better transmission ranges if the Transmitter is on PA\_MAX and the receiver is on PA\_LOW than I do with both ends on PA\_MAX
I understood from the protocol that an ACK was being sent, so it made sense that both ends were PA\_MAX to get the max range.
Anybody care to enlighten me on why this could be the case?
Should I have both receiver and transmitter the same?
Thanks
**Author:** ![Robin2](https://dub1.discourse-cdn.com/arduino/user_avatar/forum.arduino.cc/robin2/32/216045_2.png) [@Robin2](https://forum.arduino.cc/u/Robin2)\
**Post date:** [April 4, 2018, 1:34pm UTC](https://forum.arduino.cc/t/nrf24l01-power-setting-question/518289/2 "2018-04-04T13:34:45Z")
</div>
> stevef:
I have never experimented with power settings - I think all mine have been set at the maximum.
In one test I had a pair of the PCB antenna nRF24s working at 110 metres in clear line of sight outdoors. I could not try anything farther as I could not tell at a longer distance if it was working (due to poor test design 🙂 ).
My suggestion is to use whatever works best for you.
...R
[Simple nRF24L01+ Tutorial](http://forum.arduino.cc/index.php?topic=421081)
**Post date:** [May 6, 2021, 11:10am UTC](https://forum.arduino.cc/t/nrf24l01-power-setting-question/518289/3 "2021-05-06T11:10:15Z")
</div>
Closed on May 6, 2021, 11:10am UTC
