I successfully got two Nrf24l01 radio transmitters working. The transmitter is on an Arduino Mega and the receiver is on and Arduino Uno.
Then I got Adafruit's Music Maker Shield working on the Mega.
Now I want both to work at the same time.
In the sketch below, if I comment out the MP3 code then the radio works fine. If I leave the MP3 code in then nothing work.
I know that SPI can be used by multiple devices and I have been trying but with no luck. Adafruit says to make sure each device has a different CS pin. They do, the NRF24l01 has the CSN pin on 53 of the Mega and the other CS pins are 7, 6 and 4.
I do not know what to try next.
Thank you in advance.
#include <SPI.h>
#include "RF24.h"
#include <Adafruit_VS1053.h>
#include <SD.h>
// These are the pins used for the music maker shield
#define SHIELD_RESET -1 // VS1053 reset pin (unused!)
#define SHIELD_CS 7 // VS1053 chip select pin (output)
#define SHIELD_DCS 6 // VS1053 Data/command select pin (output)
// These are common pins between breakout and shield
#define CARDCS 4 // Card chip select pin
// DREQ should be an Int pin, see http://arduino.cc/en/Reference/attachInterrupt
#define DREQ 3 // VS1053 Data request, ideally an Interrupt pin
Adafruit_VS1053_FilePlayer musicPlayer =
// create shield-example object!
Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
/*** Set this radio as radio number 0 or 1 ***/
bool radioNumber = 1;
/* Hardware configuration: Set up nRF24L01 radio (CE, CSN)on SPI bus plus pins */
RF24 radio(9, 53);
// Used to control whether this node is sending or receiving
bool role = 1;
byte addresses[][6] = {"1Node", "2Node"};
byte ledState[] = {0, 0, 0, 0};
unsigned long currentMillis = 1;
delay(2000); //wait for radio 3.3v regulator to power up before sending radio commands
if (role == 0) {
pinMode(2, OUTPUT); //pinModes for recieving board
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
if (role == 1) {
pinMode(8, OUTPUT);
pinMode(14, OUTPUT);
pinMode(15, OUTPUT);
pinMode(16, OUTPUT);
// initialise the music player
if (! musicPlayer.begin()) { // initialise the music player
Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
while (1);
Serial.println(F("VS1053 found"));
if (!SD.begin(CARDCS)) {
Serial.println(F("SD failed, or not present"));
while (1); // don't do anything more
Serial.println("SD OK!");
// Set volume for left, right channels. lower numbers == louder volume!
musicPlayer.setVolume(20, 20);
} // end role 0 setup
//radio.begin();
// Set the PA Level low to prevent power supply related issues since this is a
// getting_started sketch, and the likelihood of close proximity of the devices. RF24_PA_MAX is default.
radio.setPALevel(RF24_PA_LOW);
// Open a writing and reading pipe on each radio, with opposite addresses
if (radioNumber) {
radio.openWritingPipe(addresses[1]);
radio.openReadingPipe(1, addresses[0]);
radio.openWritingPipe(addresses[0]);
radio.openReadingPipe(1, addresses[1]);
// Start the radio listening for data
radio.startListening();
currentMillis = millis();
/****************** Ping Out Role ***************************/
if (role == 1) {
if (! musicPlayer.startPlayingFile("/track001.mp3")) {
Serial.println("Could not open file track001.mp3");
while (1);
Serial.println(F("Started playing"));
radio.stopListening(); // First, stop listening so we can talk.
allOff();
delay(100);
allOn();
delay(100);
/****************** Pong Back Role ***************************/
if ( role == 0 )
if ( radio.available()) {
// Variable for the received timestamp
while (radio.available()) { // While there is data ready
radio.read( &ledState, sizeof(ledState) );
}// Get the payload
if (ledState[0] == 1) {
digitalWrite(2, HIGH);
if (ledState[0] == 0) {
digitalWrite(2, LOW);
if (ledState[1] == 1) {
digitalWrite(3, HIGH);
if (ledState[1] == 0) {
digitalWrite(3, LOW);
if (ledState[2] == 1) {
digitalWrite(4, HIGH);
if (ledState[2] == 0) {
digitalWrite(4, LOW);
if (ledState[3] == 1) {
digitalWrite(5, HIGH);
if (ledState[3] == 0) {
digitalWrite(5, LOW);
/****************** Change Roles via Serial Commands ***************************/
if ( Serial.available() )
char c = toupper(Serial.read());
if ( c == 'T' && role == 0 ) {
Serial.println(F("*** CHANGING TO TRANSMIT ROLE -- PRESS 'R' TO SWITCH BACK"));
role = 1; // Become the primary transmitter (ping out)
} else if ( c == 'R' && role == 1 ) {
Serial.println(F("*** CHANGING TO RECEIVE ROLE -- PRESS 'T' TO SWITCH BACK"));
role = 0; // Become the primary receiver (pong back)
void allOff() {
for (int i = 0; i < 13; i++) {
toggleLights(i, 0);
void allOn() {
toggleLights(i, 1);
//////////// light switch Cases ////////
void toggleLights(byte lightNo, byte pinState)
switch (lightNo)
case 1: ledState[0] = pinState;
radio.write( &ledState, sizeof(ledState) );
break;//
case 2: ledState[1] = pinState;
break;//
case 3: ledState[2] = pinState;
break;//
case 4: ledState[3] = pinState;
break;//
case 5: digitalWrite(4, pinState); break;// 19-T+
case 6: digitalWrite(5, pinState); break;// 16-T +
case 7: digitalWrite(6, pinState); break;// 47-T +
case 8: digitalWrite(7, pinState); break;// 43-T +
case 9: digitalWrite(8, pinState); break;// 43-T +
case 10: digitalWrite(14, pinState); break;// 43-T +
case 11: digitalWrite(15, pinState); break;// 43-T +
case 12: digitalWrite(16, pinState); break;// 43-T +
