nrf24l01+ radio.write() FAILS (and can't figure out why) =(
Hi everybody,
I’ve spent a lot of time trying to use two nrf24l01+ modules to create a wireless sensor network.
My intent is to send humidity and temperature from a DHT11 sensor to a reciever placed in another room.
Tried a lot of examples found on the web, but without luck … only the example pingpair.pde of the RF24 class worked once.
I found this code on RF24 library revisited , and modified it a bit to meet my project but is still not working and I cannot figure out why
The code of sender is:
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include <dht11.h>
dht11 DHT;
#define DHT11_PIN 4
int data[2];
RF24 radio(9,10);
const uint64_t pipe = 0xE8E8F0F0E1LL;
bool success;
void setup(void)
  radio.begin();
  radio.openWritingPipe(pipe);
  //Check sensor once starting
  int chk;
  Serial.print("DHT11, \t");
  chk = DHT.read(DHT11_PIN);    // READ DATA
  switch (chk){
    case DHTLIB_OK:
                Serial.print("OK,\t");
    case DHTLIB_ERROR_CHECKSUM:
                Serial.print("Checksum error,\t");
    case DHTLIB_ERROR_TIMEOUT:
                Serial.print("Time out error,\t");
    default:
                Serial.print("Unknown error,\t");
void loop(void)
  data[0] = DHT.humidity;
  Serial.print(data[0]);
  Serial.print(" , ");
  data[1] = DHT.temperature;
  Serial.println(data[1]);
  success = radio.write( data, sizeof(data) );
  switch(success){
    case true:
      Serial.println("OK");
    case false:
      Serial.println("Failed");
The problem is that function radio.write() fails instead of succeding, wich means that the message was not sended !
Someone can help me ?
Thanks in advance
Uge
Its been a while since I used the RF24 stuff, but I'd check the return values from
  radio.begin();
Also. Generally don't both using a switch statement when you only have 2 results ie true or false
And you don't need to waste a variable to store it, if you are not using that response later
  if (radio.write( data, sizeof(data) ){
Hi Roger, thanks for your help.
Unfortunately radio.begin() and radio,openWritigPipe() are void functions, so do not returns anything ... how can I test them ?
(sorry for the question, I'm not an experienced programmer)
