nRF24L01 receiving gibberish data
Hi. so I was trying to make 2 nRF24L01 modules to send data. One was the transmitter (let's take it as a) and the other was the receiver (as b). So i wrote a simple code to send "Hello World" from a to b and print it in the serial monitor, but the receiver was sending gibberish even if the transmitter was turned off. Transmitter's code:
#include <RF24.h>
#include <nRF24L01.h>
#include <SPI.h>
RF24 radio(8, 7);
const byte address[6] = "Ju39x";
  radio.begin();
  radio.openWritingPipe(address);
  radio.setPALevel(RF24_PA_HIGH);
  radio.stopListening();
  const char text[] = "Hello World";
  radio.write(&text, sizeof(text));
Receiver's code:
#include <RF24.h>
#include <SPI.h>
RF24 radio(8, 7);
  radio.begin();
  radio.openReadingPipe(0, address);
  radio.startListening();
  if (radio.available())
    char text[32] = "";
    radio.read(&text, sizeof(text));
    Serial.println(text);
How do I fix this?
As you've not indicated otherwise, you could start with the excellent tutorials here:
Start with the connection check sketch further on in the thread (post #30) before trying the simple tx rx sketches to check that your radios are working correctly.
Connect the receiver properly.
If it is not connected, 0xFF is very often received instead of real data.
Since packetAvailable is a bit that gets set in a control register,
you will see phantom packets with junk content.
I tried that sketch, but it is showing 0x00 and 0xff in all the fields
here is the serial monitor:
FIRST WITH THE DEFAULT ADDRESSES after power on
  Note that RF24 does NOT reset when Arduino resets - only when power is removed
  If the numbers are mostly 0x00 or 0xff it means that the Arduino is not
     communicating with the nRF24
STATUS		 = 0x00 RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=0 TX_FULL=0
RX_ADDR_P0-1	 = 0x0000000000 0x0000000000
RX_ADDR_P2-5	 = 0x00 0x00 0x00 0x00
TX_ADDR		 = 0x0000000000
RX_PW_P0-6	 = 0x00 0x00 0x00 0x00 0x00 0x00
EN_AA		 = 0xff
EN_RXADDR	 = 0x00
RF_CH		 = 0x00
RF_SETUP	 = 0x00
CONFIG		 = 0x00
DYNPD/FEATURE	 = 0x00 0x00
Data Rate	 = 1MBPS
Model		 = nRF24L01
CRC Length	 = 8 bits
PA Power	 = PA_MIN
AND NOW WITH ADDRESS AAAxR  0x41 41 41 78 52   ON P1
 and 250KBPS data rate
EN_AA		 = 0xff
EN_RXADDR	 = 0x00
RF_CH		 = 0x00
RF_SETUP	 = 0x00
CONFIG		 = 0x00
Data Rate	 = 1MBPS
Model		 = nRF24L01
CRC Length	 = 8 bits
PA Power	 = PA_MIN
the second module seems to be working, serial monitor of the second module:
CheckConnection Starting
STATUS		 = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
RX_ADDR_P0-1	 = 0xe7e7e7e7e7 0x4141417852
RX_ADDR_P2-5	 = 0xc3 0xc4 0xc5 0xc6
TX_ADDR		 = 0xe7e7e7e7e7
RX_PW_P0-6	 = 0x00 0x20 0x00 0x00 0x00 0x00
EN_AA		 = 0x3f
EN_RXADDR	 = 0x03
RF_CH		 = 0x4c
RF_SETUP	 = 0x07
CONFIG		 = 0x0e
Data Rate	 = 1MBPS
Model		 = nRF24L01+
CRC Length	 = 16 bits
PA Power	 = PA_MAX
EN_AA		 = 0x3f
EN_RXADDR	 = 0x03
RF_CH		 = 0x4c
RF_SETUP	 = 0x27
CONFIG		 = 0x0e
Data Rate	 = 250KBPS
Model		 = nRF24L01+
PA Power	 = PA_MAX
Now would be a good time to tell us what hardware you are using, and how you have connected the radio modules.
ah i am sorry about that. i am using 2 arduino unos and 2 nrf24l01 modules
ok so i switched the positions of CE and CSN and it is now working
