First question I was wondering what sort of reliability people are getting with this module and RF24 library
in the pingpair example about every 10th send fails.. sometimes it will send 100 in a row fine and sometime 10 in a row might fail. I used the scanner tool to find an open channel(120 is what I ended up using as there is nothing anywhere near it)
so ultimately I want to make a wireless SNES controller and have done so.. its fairly reliable if I use 'startWrite' instead of 'write' with write it fails almost all the time.. the data I am sending is a 16bit number sent as decimal(0-4095) if I set the payload size to anything but default it fails A LOT more so my guess is I am defining the payload incorrectly
i have 10 NRF24L01+ modules and to be sure its not an issue with one of them I checked them all and all have same results.
here is the output of the sending(controller) info display:
ROLE: Controller
STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
RX_ADDR_P0-1 = 0xe8e8f0f0e1 0xc2c2c2c2c2
RX_ADDR_P2-5 = 0xc3 0xc4 0xc5 0xc6
TX_ADDR = 0xe8e8f0f0e1
RX_PW_P0-6 = 0x20 0x00 0x00 0x00 0x00 0x00
EN_AA = 0x3f
EN_RXADDR = 0x03
RF_CH = 0x78
RF_SETUP = 0x07
CONFIG = 0x0e
DYNPD/FEATURE = 0x00 0x00
Data Rate = 1MBPS
Model = nRF24L01+
CRC Length = 16 bits
PA Power = PA_HIGH
This is the code I am using now that is fairly reliable but I notice the odd time it doesn't send a key like it should but games are completely playable with it... I put the same code on the transmitter(controller) and Reciever I am using an UNO and a Leonardo.. I simply comment out the Keyboard lines for the UNO when I upload it.
#include <digitalWriteFast.h>
#include <NESPad2.h>
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include "printf.h"
int msg[1];
const char letterOutput[12] = {
216, // Left
215, // Right
218, // Up
217, // Down
'z', // B
'a', // Y
133, // Select - RShift
176, // Start - Enter
'x', // A
's', // X
'q', // L
'w', // R
int SNESbuttons[12];
int button_data;
// Set up nRF24L01 radio on SPI bus plus pins 9 & 10
RF24 radio(9,10);
const int role_pin = 7;
// Radio pipe addresses for the 2 nodes to communicate.
const uint64_t pipe = 0xE8E8F0F0E1LL;
// The various roles supported by this sketch
typedef enum { role_Controller = 1, role_RCV } role_e;
// The debug-friendly names of those roles
const char* role_friendly_name[] = { "invalid", "Controller", "Reciever"};
// The role of the current running sketch
role_e role;
// Role
// set up the role pin
pinMode(role_pin, INPUT);
digitalWrite(role_pin,HIGH);
delay(20); // Just to get a solid reading on the role pin
// read the address pin, establish our role
if ( ! digitalRead(role_pin) ) {
role = role_Controller;
else {
role = role_RCV;
Serial.begin(57600);
if ( role == role_RCV ) {
delay(5000);
printf_begin();
printf("ROLE: %s\n\r",role_friendly_name[role]);
// Setup and configure rf radio
radio.begin();
// optionally, increase the delay between retries & # of retries
radio.setRetries(15,0);
// optionally, reduce the payload size. seems to
// improve reliability
radio.setChannel(120);
if ( role == role_Controller ) {
radio.openWritingPipe(pipe);
NESPad::init();
else {
radio.openReadingPipe(1,pipe);
// Start listening
radio.startListening();
// Dump the configuration of the rf unit for debugging
radio.printDetails();
if (role == role_Controller) {
msg[0] = NESPad::read(16);
radio.startWrite(msg,2);
delay(20);
if (role == role_RCV) {
// if there is data ready
if (radio.available()){
// Dump the payloads until we've gotten everything
bool done = false;
while (!done) {
// Fetch the payload, and see if this was the last one.
done = radio.read(msg,2);
button_data = msg[0];
snes_read();
void snes_read() {
SNESbuttons[0] = button_data & 64; // Left
SNESbuttons[1] = button_data & 128; // Right
SNESbuttons[2] = button_data & 16; // Up
SNESbuttons[3] = button_data & 32; // Down
SNESbuttons[4] = button_data & 1; // B
SNESbuttons[5] = button_data & 2; // Y
SNESbuttons[6] = button_data & 4; // Select
SNESbuttons[7] = button_data & 8; // Start
SNESbuttons[8] = button_data & 256; // A
SNESbuttons[9] = button_data & 512; // X
SNESbuttons[10] = button_data & 1024; // L
SNESbuttons[11] = button_data & 2048; // R
int i = 12;
while(i--) {
if (SNESbuttons[i]) {
Keyboard.press(letterOutput[i]);
else {
Keyboard.release(letterOutput[i]);
this is the code that doesn't work very well(a lot of fails) I assume the above has just as many fails but it sends non-stop so it makes up for it.... also i set retries to 15 when using the below code.
bool different = false;
button_data = NESPad::read(16);
if (msg[0] != button_data) {
different = true;
msg[0] = button_data;
if (different) {
printf("Now sending...%d... ",msg[0]);
bool ok = radio.write(msg,2);
if (ok)
printf("ok\n\r");
printf("failed\n\r");
delay(20);
