NRF24L01+ Stops Transmitting After Exactly 33 Seconds
Hi everyone,
This is a real head scratcher for me. I have an Arduino Uno (powered off USB) transmitting to an RC vehicle using NRF24L01+'s with the RF24 Fork library. Everything works, fantastically. But then I hit the 33rd second of transmitting and it suddenly ceases to transmitting. Testing seems to indicate it is definitely on the transmitter side of things.
It is reading a potentiometer. The “failureDetected” method never gets called, it just stops transmitting out of the blue, no errors or anything. It definitely isn’t the potentiometer, even when I set it to transmit a set number constantly, it still fails after 33 seconds.
I did try a 47μF capacitor and a 100μF capacitor on the VCC and GND pins of the NRF24L01+ and the problem remains exactly the same.
Here is my code. Please be kind, I have never had any technical training whatsoever and learned everything I know from google, I am a biology student not a computer science student :slight_smile:
                CONTROLLER SOFTWARE
//radio includes
#include <SPI.h>
#include "RF24.h"
#include <printf.h>
const uint64_t pipes[2] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0D2LL };
RF24 radio(7, 8);
int currentTime = 0;
int nextTime = 0;
const unsigned int measurementInterval = 10; //sampling rate of the potentiometer
float currentThrottle = 0;
float previousThrottles[10];
float averageThrottle = 0;
void setup ()
  Serial.begin(57600);
  printf_begin();
  radio.begin();
  radio.setRetries(15, 15);
  radio.setPayloadSize(sizeof(unsigned long));
  radio.setPALevel(RF24_PA_MAX);
  radio.setChannel(16);
  radio.openWritingPipe(pipes[0]);
  radio.openReadingPipe(1,pipes[1]);
  radio.startListening();
  radio.printDetails();
  Serial.println("Finished setup...");
  nextTime = currentTime + measurementInterval;
void loop ()
  currentTime = millis();
  if (millis() >= nextTime) {
    nextTime = millis() + measurementInterval;
    float throttleReading = analogRead(A0);
    float adjustment = 0.1854;
    currentThrottle = adjustment * throttleReading;
    for (int i = 0; i < 9; i++) {
      previousThrottles[i] = previousThrottles[i + 1];
    previousThrottles[9] = currentThrottle;
    for (int i = 0; i < 10; i++) {
      averageThrottle += previousThrottles[i];
    averageThrottle = averageThrottle / 9;
    if (averageThrottle > 20) {
      radio.stopListening();
      unsigned long yyt = long(averageThrottle);
      bool ok = radio.write(&yyt, sizeof(unsigned long));
      if (!ok) {
        Serial.print("Failed to send throttle: \t");
        Serial.println(yyt);
        Serial.println("Success");
        Serial.println(averageThrottle);
    if(radio.failureDetected){
      radio.begin();
      Serial.println("FAILURE DETECTED");
      // Attempt to re-configure the radio with defaults
      radio.failureDetected = 0;           // Reset the detection value
      radio.setPALevel(RF24_PA_MIN);
My first suggestion would be to take a closer look at the datatypes used in Arduino, specifically int vs unsigned int or unsigned long.
Then try out the following code, and note the changes at the very end.
                CONTROLLER SOFTWARE
//radio includes
#include <SPI.h>
#include "RF24.h"
#include <printf.h>
RF24 radio(7, 8);
int nextTime = 0;
void setup ()
  printf_begin();
  radio.begin();
void loop ()
      if (!ok) {
      radio.begin();
  }else{
    Serial.print("m: ");
    Serial.println( millis());
    Serial.print("n: ");
    Serial.println(nextTime);
I hope this will give you enough information to solve the problem on your own, and an idea of how to begin troubleshooting such a problem, but if you are still confused, I can post the explanation.
int nextTime = 0;
You will overflow the currentTime variable where (currentTime = millis();) very quickly and like TMRh20 suggests you you should take a look to data types. These two variables should be of type long.
That was so obvious. WOW. How did I not notice that? I knew it was some obvious mistake in my code that I was not catching but I wish it had been something a little less easy. lol
Thank you both so much :D
