NRF24L01+ (TMRH20 library): How read a string sent?
Basically I have a PI that sends a string (“get”) to an Arduino.
I did edit the gettingstarted_caller.cpp example, but I cannot receive the ACK from Arduino.
It seems that Arduino cannot read the text sent.
This is my arduino code:
#include <SPI.h>
#include "RF24.h"
const int LED = 6;
/****************** User Config ***************************/
/***      Set this radio as radio number 0 or 1         ***/
bool radioNumber = 0;
/* Hardware configuration: Set up nRF24L01 radio on SPI bus plus pins 7 & 8 */
RF24 radio(7,8);
// Topology
byte addresses[][6] = {"1Node","2Node"};              // Radio pipe addresses for the 2 nodes to communicate.
byte counter = 1;                                                          // A single byte to keep track of the data being sent back and forth
void setup(){
  pinMode(LED, OUTPUT);
  digitalWrite(LED,HIGH);
  // Setup and configure radio
  radio.begin();
  radio.enableAckPayload();                     // Allow optional ack payloads
  radio.enableDynamicPayloads();                // Ack payloads are dynamic payloads
  if(radioNumber){
    radio.openWritingPipe(addresses[1]);        // Both radios listen on the same pipes by default, but opposite addresses
    radio.openReadingPipe(1,addresses[0]);      // Open a reading pipe on address 0, pipe 1
  }else{
    radio.openWritingPipe(addresses[0]);
    radio.openReadingPipe(1,addresses[1]);
  radio.startListening();                       // Start listening
  radio.writeAckPayload(1,&counter,1);          // Pre-load an ack-paylod into the FIFO buffer for pipe 1
  radio.printDetails();
  byte pipe;
  //if (radio.available(&pipe)) {
  while(radio.available(&pipe)) {
    char text[32] = {0};
    radio.read(&text, sizeof(text));
    if (text=="get") {
      Serial.println("TEXT == GET");
      int state = digitalRead(LED);
      radio.writeAckPayload(pipe,&state,sizeof(state));              // This can be commented out to send empty payloads.
    if (text=="1") {
    if (text=="0") {
      digitalWrite(LED,LOW);
    Serial.println(text);
And this is the PI c++ code:
#include <cstdlib>
#include <iostream>
#include <sstream>
#include <string>
#include <unistd.h>
#include <RF24/RF24.h>
using namespace std;
// Radio CE Pin, CSN Pin, SPI Speed
// See http://www.airspayce.com/mikem/bcm2835/group__constants.html#ga63c029bd6500167152db4e57736d0939 and the related enumerations for pin information.
RF24 radio(RPI_V2_GPIO_P1_15, RPI_V2_GPIO_P1_24, BCM2835_SPI_SPEED_8MHZ);
/********** User Config *********/
// Assign a unique identifier for this node, 0 or 1. Arduino example uses radioNumber 0 by default.
bool radioNumber = 1;
const uint8_t addresses[][6] = {"1Node","2Node"};
//uint8_t counter = 1; // A single byte to keep track of the data being sent back and forth
char text_get[] = "get";
char text_set_on[] = "1";
char text_set_off[] = "0";
int main(int argc, char** argv){
  //int size_text = sizeOf(text);
  radio.begin();
  radio.printDetails();                   // Dump the configuration of the rf unit for debugging
  // This opens two pipes for these two nodes to communicate
  // back and forth.
    if ( !radioNumber )    {
    }else{
    //radio.startListening();
    //radio.writeAckPayload(1,&counter,1);
    // pipeAddress (1), il messaggio e la taglia del messaggio
    //radio.writeAckPayload(1,&text,sizeof(text));
// forever loop
while (1){
    //uint8_t gotByte;                                        // Initialize a variable for the incoming response
    char answer[32];
    radio.stopListening();                                  // First, stop listening so we can talk.
    printf("Now sending %s as payload. ",text_get);          // Use a simple byte counter as payload
    unsigned long time = millis();                          // Record the current microsecond count
    if ( radio.write(&text_get,sizeof(text_get)) ){         // Send the counter variable to the other radio
        if(!radio.available()){                             // If nothing in the buffer, we got an ack but it is blank
            printf("Got blank response. round-trip delay: %lu ms\n\r",millis()-time);
        }else{
            while(radio.available() ){                      // If an ack with payload was received
                radio.read( &answer, sizeof(answer) );                  // Read it, and display the response time
		printf("Got response %s, round-trip delay: %lu ms\n\r",answer,millis()-time);
 	printf("Sending failed.\n\r");
    }          // If no ack response, sending failed
    sleep(1);  // Try again later
} //while 1
} //main
PI print every line with a laconic:
Now sending get as payload. Got blank response. round-trip delay: 1 ms
So, PI receives the ACK but is blank… :frowning:
PS Of course with basic example all functions. Radio functions and see every other.
Thank you for your help
I don’t know why you have the complication of bool radioNumber = 0; when you are having difficulty getting basic communication to work. Just write simple programs on the PI and on the Arduino with neither program having any options.
I don’t have a PI so I don’t know how to use an nRF24 with it. I presume it is pretty much the same as for an Arduino and this Simple nRF24L01+ Tutorial may help. Start with the first, simplest example.
…R
You are, for sure, right.
I did start with easy example of the library. Now editing them.
By the way, I saw now your guide, and you make an important affermation for me:
the ackPayoad cannot take account of the data received in the message for which it is the acknowledgment.
In effect I would "respond" with an ACK with the state of a Arduino PIN. But it seems impossible. So, maybe this was my problem.
THank you very much!
sineverba:
Yes. The ackPayload must be loaded before the message arrives.
This means that the ackPayload is at least one step behind. For many applications that does not matter - especially if messages are sent several times per second.
...R
@Robin2, I abuse of your knowledge.
In your first example, you trasmit a fixed lenght message.
I.e. in your RX you have:
char dataReceived[10]; // this must match dataToSend in the TX
But... if in receiver I don't know exact length, how I can do? I'm initialize an array of 32?
I'm yet doint in this manner:
    radio.writeAckPayload(pipe,&counter,1);              // This can be commented out to send empty payloads.
But I would know if is best mode to do.
Thank you very much!
You could (should) use
    char text[32];
    radio.read(text, radio.getDynamicPayloadSize());
    radio.writeAckPayload(pipe, &counter, 1); // one byte ack-payload
Remember that the '\0' has to be transmitted or added after reception.
If you add the delimiter after reception your buffer needs to be one byte longer.
    char text[33];
    byte rxLen = radio.getDynamicPayloadSize();
    radio.read(text, rxLen);
    text[rxLen] = 0;
sineverba:
You can use dynamic payloads as @Whandall has said.
However for a beginner it may be easier to use fixed length payloads of the largest size you will need.
Also, as @Whandall has said a cstring needs an extra space for the terminating \0. Again, the simplest thing is probably to limit yourself to a maximum text size of 31 characters to allow for the terminating \0
Because my second example uses the ackPayload feature it automatically uses dynamic payloads - so that might be another simple option.
...R
