alb12
May 15, 2018, 8:31am
1
Hello,
I have multi device with nrf24l01, but I have a transmission problem between some devices.
Topology:
Gateway ( node id 0 ) => NRF24L01+
Node 1 => NRF24L01 + pa + lna with antenna ( https://bit.ly/2jWPaLv )
Node 31 => NRF24L01+ ( child of Node 1 )
Descritpition:
Transmission between 0 and 1 no problem ( two separation wall )
Transmission between 1 and 31 problem ( 1 floor and several wall )
The node 31 receive some times ( normaly when the node received it send data to node 0 ) but the data send by this node is never received.
If I bring node 31 closer to node 1, no problem.
Normally the NRF24L01 PA LNA at a long range
Have you idea ?
You could see my module on this blog ( http://domotique-diy.over-blog.com/ )
Thanks
Obviously, node 31 needs more signal strength.... replace it with a model that also has the power amp and low noise amp (and an external antenna).
How many nRF24s have you in the network?
Please post a diagram to illustrate how they are positioned relative to each other.
Please confirm that everything works properly when the distances are shorter.
Have you tried using a different channel in case the problem is interference from some other device?
...R
MarkT
May 15, 2018, 9:55pm
4
Have you tried moving the nodes around to avoid RF dead spots?
high speed low power 2.4GHz devices with small antenna do not have a long range, especially
as they have to compete with the 2.4GHz leakage from microwave ovens and WiFi spread-spectrum
signals.
alb12
May 16, 2018, 7:55am
5
I have 3 nRF24:
Gateway node Id 0
Node 1
Node 31
I have make many test on different position for Node 31.
When the distance is short no problem.
You can see on this picture the distance ( in meter )who I have the probleme with node 31.
Communication between N0 and N1 no problem.
N1 and N0 are on 1st floor, N31 is on ground floor
N1 is NRF24L01+pa+LNA
alb12
May 16, 2018, 8:36am
6
@123Splat , I can't replace the nRF24 of node 31, because the nRF24 is solder on the PCB and it's specific for the size of the box containing.
Yes if I moved the nRF24 around the RF dead spots, it's ok but I can't add new node between.
If I update the antenna of node 1 like a 8db or 12 db, do you think this can solve the problem ?
Thanks
Thank you for the very clear diagram.
Have you tried moving the high-power nRF24 to Node31 - i.e. the distant one?
I have had a pair of low power nRF24s (with PCB antenna) working at 110m distance outdoors in straight line of sight.
You have not said whether you have tried different channels?
Trees (and green foliage generally) can easily absorb 2.4GHz wireless signals.
Your Node31 seems to be partially shielded by the building in front of it. Can you raise it above the level of that building?
...R
MarkT
May 16, 2018, 9:32am
8
antennas with gain are directional, so it'll require some experimentation to get the best alignment.
alb12
May 16, 2018, 10:34am
10
No I haven't change the channels.
The node 31 have a low power nRF24 ( with PCB antenna ), I can't change and it can only be in the building.
I have try to move the node 31 ( 44.33 m ) in front of the first building and it's better, but like I said previously, it can only be in the building.
Robin2
May 16, 2018, 11:32am
11
alb12:
It's well worth trying
Why ever not? Isn't it as simple as plugging out the nRF24s and plugging them in somewhere else?
...R
alb12
May 16, 2018, 1:03pm
12
Yes I wll try to change the channels, I use the tmrh20 library and I haven't specify channel for the moment.
Reason:
See here:
http://tmrh20.github.io/RF24Network/classRF24Network.html
#include <RF24.h>
#include <RF24Network.h>
const uint16_t this_node = 031;
radio.begin();
radio.setDataRate(RF24_250KBPS);
network.begin(this_node);
Because it's solder on the PCB. ( Domotiser un appareil grâce à un relai V2 - La domotique DIY
MarkT
May 16, 2018, 1:39pm
13
There is no such thing as an omnidirectional antenna with gain, that's a collinear array. It beams out sideways.
alb12
May 16, 2018, 2:08pm
14
So if I change my antenna 2db by antenna omnidirectional 8 or 12 db, the problem will be same ?
Robin2
May 16, 2018, 2:50pm
15
alb12:
Reason:
If you look at your link you will see that it says
Note
Use radio.setChannel() to configure the radio channel
Maybe it would be wise to invest in another high-power nRF24 - or invest in a desoldering pump.
...R
alb12
May 16, 2018, 3:03pm
16
Ok, and If I change the antenna of node 1 ( 2db ) by antenna of 8 or 12 db ?
Robin2
May 16, 2018, 3:23pm
17
alb12:
I don't understand. I thought you said you cannot change the nRF24.
And I always get my decibels mixed up - is 8 more or less powerful than 2?
...R
MarkT
May 16, 2018, 3:47pm
18
There is no such thing as an omnidirectional antenna with gain. Its a beaming antenna so you
must point it right for best signal.
alb12
May 16, 2018, 5:16pm
19
Yes for the node 31, but if I change the antenna of node 1 ( See my Schema ).
Normally 8db is more powerful than 2db
Robin2
May 16, 2018, 6:39pm
20
alb12:
Sorry. I feel I am being really dumb here. I thought you said earlier that Node1 is the node with the high-power Arduino?
...R
