nrf24l01+ while loop problem
in led remote examples in the part
if ( radio.available() ) { // Dump the payloads until we've gotten everything
bool done = false; while (!done) { // Fetch the payload, and see if this was the last one. done= radio.read( button_states, num_button_pins);
i get
led_remote_2.ino: In function 'void loop()': led_remote_2.ino:237:12: error: void value not ignored as it ought to be
please help me
Perhaps they can help you at http://snippets-r-us.com.
Always post all your code and use code tags to make it readable - the # button
The error is on or before line 237.
...R
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include "printf.h"
// Hardware configuration
// Set up nRF24L01 radio on SPI bus plus pins 9 & 10
RF24 radio(9,10);
// sets the role of this unit in hardware.  Connect to GND to be the 'led' board receiver
// Leave open to be the 'remote' transmitter
const int role_pin = A4;
// Pins on the remote for buttons
const uint8_t button_pins[] = { 2,3,4,5,6,7 };
const uint8_t num_button_pins = sizeof(button_pins);
// Pins on the LED board for LED's
const uint8_t led_pins[] = { 2,3,4,5,6,7 };
const uint8_t num_led_pins = sizeof(led_pins);
// Topology
// Single radio pipe address for the 2 nodes to communicate.
const uint64_t pipe = 0xE8E8F0F0E1LL;
// Role management
// Set up role.  This sketch uses the same software for all the nodes in this
// system.  Doing so greatly simplifies testing.  The hardware itself specifies
// which node it is.
// This is done through the role_pin
// The various roles supported by this sketch
typedef enum { role_remote = 1, role_led } role_e;
// The debug-friendly names of those roles
const char* role_friendly_name[] = { "invalid", "Remote", "LED Board"};
// The role of the current running sketch
role_e role;
// Payload
uint8_t button_states[num_button_pins];
uint8_t led_states[num_led_pins];
// Setup
void setup(void)
  // Role
  // set up the role pin
  pinMode(role_pin, INPUT);
  digitalWrite(role_pin,HIGH);
  delay(20); // Just to get a solid reading on the role pin
  // read the address pin, establish our role
  if ( digitalRead(role_pin) )
    role = role_remote;
    role = role_led;
  // Print preamble
  Serial.begin(57600);
  printf_begin();
  printf("\n\rRF24/examples/led_remote/\n\r");
  printf("ROLE: %s\n\r",role_friendly_name[role]);
  // Setup and configure rf radio
  radio.begin();
  // Open pipes to other nodes for communication
  // This simple sketch opens a single pipes for these two nodes to communicate
  // back and forth.  One listens on it, the other talks to it.
  if ( role == role_remote )
    radio.openWritingPipe(pipe);
    radio.openReadingPipe(1,pipe);
  // Start listening
  if ( role == role_led )
    radio.startListening();
  // Dump the configuration of the rf unit for debugging
  radio.printDetails();
  // Set up buttons / LED's
  // Set pull-up resistors for all buttons
    int i = num_button_pins;
    while(i--)
      pinMode(button_pins[i],INPUT);
      digitalWrite(button_pins[i],HIGH);
  // Turn LED's ON until we start getting keys
    int i = num_led_pins;
    while(i--)
      pinMode(led_pins[i],OUTPUT);
      led_states[i] = HIGH;
      digitalWrite(led_pins[i],led_states[i]);
// Loop
void loop(void)
  // Remote role.  If the state of any button has changed, send the whole state of
  // all buttons.
    // Get the current state of buttons, and
    // Test if the current state is different from the last state we sent
    bool different = false;
    while(i--)
      uint8_t state = ! digitalRead(button_pins[i]);
      if ( state != button_states[i] )
        different = true;
        button_states[i] = state;
    // Send the state of the buttons to the LED board
    if ( different )
      printf("Now sending...");
      bool ok = radio.write( button_states, num_button_pins );
      if (ok)
        printf("ok\n\r");
        printf("failed\n\r");
    // Try again in a short while
    delay(20);
  // LED role.  Receive the state of all buttons, and reflect that in the LEDs
    // if there is data ready
      bool done = false;
      while (!done)
        done = radio.read( button_states, num_button_pins );
        // Spew it
        printf("Got buttons\n\r");
        // For each button, if the button now on, then toggle the LED
        while(i--)
          if ( button_states[i] )
            led_states[i] ^= HIGH;
// vim:ai:cin:sts=2 sw=2 ft=cpp
i know its on the line 237 but i cant understand how to fix it…
That code only has 228 lines and it compiles without error for me.
Pete
I was rather hping you would tell me which is line 237.
And, as @el_supremo says the code you posted only has 228 lines
...R
