I have been working on a project lately and I keep bumping into trouble. The Setup is pretty basic there will be multiple sensors connected to different places in our farm and they will send information to a monitor located inside my house. But hey lets test each module to check whether or not the connection is working or not...And they don,t! I am using the nrf24l01 wireless com module, the code is pretty self explanatory. I used to use an older version of the nrf24 library but with a little bit of digging I thought that upgrading to tmrh20 library... and now it does not even complete the loop. My connections are all right. last time I did not have a receiver while I was using the autoACK() and obviously It did not work anyway I still cant make it work and I have made some fixes to the setup...it still does not work.
// The transmitter code is as follows just ignore the parts about temperature readings
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <RF24_config.h>
#include <OneWire.h>
#ifndef __PRINTF_H__
#define __PRINTF_H__
#ifdef ARDUINO
int serial_putc( char c, FILE * )
Serial.write( c );
return c;
void printf_begin(void)
fdevopen( &serial_putc, 0 );
#else
#error //This example is only for use on Arduino.
#endif // ARDUINO
#endif // __PRINTF_H__
int DS18S20_Pin = 2; // sets data pin to pin2
OneWire ds(DS18S20_Pin);
// wifi info
const int CSN = 10;
const int CE = 9;
byte LED1 = 3;
byte LED2 = 4;
byte counter = 1; //used to count the packets sent
bool done = false;
RF24 radio(CE,CSN); //CE, CSN
const uint64_t rAdress = 0xE8E8F0F0E1LL;
void setup(void) {
radio.begin(); //Start the nRF24 module
radio.setAutoAck(1); // / Ensure autoACK is enabled so rec sends ack packet to let you know it got the packet
radio.enableAckPayload();
radio.openWritingPipe(rAdress); //open writing pipe
radio.setPALevel(RF24_PA_MAX);
radio.stopListening(); //go into transmit mode
radio.printDetails();
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
void loop(void) {
// gets the temperaute in celcius from the ds18s20
float temperature = getTemp();
Serial.print("Temperature: "); // shows the temperature value
Serial.println(temperature);
Serial.print("Now send packet: ");
Serial.println(counter); //serial print the packet number that is being sent
unsigned long time1 = micros(); //start timer to measure round trip
Serial.print("The payload size is: ");
Serial.println(radio.getDynamicPayloadSize());
//send or write the packet to the rec nRF24 module. Arguments are the payload / variable address and size
if (!radio.write(&temperature,sizeof(float))){ //if the send fails let the user know over serial monitor
Serial.println("packet delivery failed");
digitalWrite(LED2, HIGH); // leds are good manual tools to check if everything is working well
digitalWrite(LED1,LOW);
else { //if the send was successful
unsigned long time2 = micros(); //get time new time
time2 = time2 - time1; //calculate round trip time to send packet
Serial.print("Time from message sent to recieve Ack packet: ");
Serial.print(time2); //print the time to the serial monitor
Serial.println(" microseconds");
counter++; //up the packet count
if (temperature < -273) { // when the sensor is not connceted the getTemp() function prints -1000 and -273C is the coldest it can can in this universe...
Serial.println("ERROR: TEMPERATURE SENSOR NOT CONNECTED!");
digitalWrite(LED1,LOW);}
else if ( radio.write(&temperature,sizeof(temperature)) && temperature < -273 ) {
digitalWrite(LED2, LOW);
digitalWrite(LED1,HIGH);}
delay(100);
float getTemp(){ //returns the temperature from one DS18S20 in DEG Celsius
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
//no more sensors on chain, reset search
ds.reset_search();
return -1000;
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return -1000;
if ( addr[0] != 0x10 && addr[0] != 0x28) {
Serial.print("Device is not recognized");
return -1000;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
byte present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for (int i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
ds.reset_search();
byte MSB = data[1];
byte LSB = data[0];
float tempRead = ((MSB << 8) | LSB); //using two's compliment
float TemperatureSum = tempRead / 16;
return TemperatureSum;
// Serial output for this is as follows and neither LEDs light
STATUS = 0x0e RX_DR=0 TX_DS=0 STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
RX_ADDR_P0-1 = 0xe8e8f0f0e1 0xc2c2c2c2c2
RX_ADDR_P2-5 = 0xc3 0xc4 0xc5 0xc6
TX_ADDR = 0xe8e8f0f0e1
RX_PW_P0-6 = 0x20 0x00 0x00 0x00 0x00 0x00
EN_AA = 0x3f
EN_RXADDR = 0x03
RF_CH = 0x4c
RF_SETUP = 0x07
CONFIG = 0x0e
DYNPD/FEATURE = 0x03 0x06
Data Rate = 1MBPS
Model = nRF24L01+
CRC Length = 16 bits
PA Power = PA_MAX
Temperature: 26.19
Now send packet: 1
The payload size is: 0
// this means the code has some trouble with the if(radio.write()) part as it just stops there
//The receiver code is as follows
#include <RF24.h>
#include <SPI.h>
#ifdef ARDUINO
Serial.write( c );
return c;
#else
#endif // ARDUINO
// wifi info
const int CSN = 10;
const int CE = 9;
byte LED1 = 3;
byte LED2 = 4;
const uint64_t tAdress = 0xE8E8F0F0E1LL;
float temperature = -1000;
int payload_size;
radio.openReadingPipe(1,tAdress); //open reading pipe
radio.startListening(); //go into receiving mode
while(radio.available()){
Serial.println("comms available");
radio.read( &temperature, sizeof(float) ); //read size of data and store it in tempersture variable
Serial.print("Temperature: "); //payload counts packet number
Serial.println(temperature); //print payload / packet number
Serial.println("no comms available");
payload_size = radio.getDynamicPayloadSize();
Serial.println(payload_size);
The serial output for this part is as follows
RX_ADDR_P0-1 = 0xe7e7e7e7e7 0xe8e8f0f0e1
TX_ADDR = 0xe7e7e7e7e7
RX_PW_P0-6 = 0x00 0x20 0x00 0x00 0x00 0x00
EN_AA = 0x3f
EN_RXADDR = 0x02
RF_CH = 0x4c
RF_SETUP = 0x07
CONFIG = 0x0f
Data Rate = 1MBPS
Model = nRF24L01+
PA Power = PA_MAX
no comms available
no comms available
no comms available
no comms available
no comms available
no comms available
no comms available
no comms available
no comms available
no comms available
no comms available
no comms available
no comms available
// I guess no signal ever leaves the transmitter what may be the problem ? I know these nrf24l01 modules work properly, it either has something to do with my code or I had done something wrong uploading the library or something...can you please help.
