NRF24L01 WIRELESS MODULE | Secure Connection | Need Help
Hey Creators!
I'm creating an Arduino Project that uses an NRF24L01 Wireless Module. So, in this project I want to send data wirelessly over a distance of about 500 meters.
I want the connection to be secured between the two modules and don't want any other same module to receive data sent from any of the connected modules so that the sent data can't be copied by anyone in the range.
I want to know, if there is a way to do so.
Thank You.
I think you'll need an amplifier module like one of these for that kind of range.
You'll have to use some kind of encryption to keep anyone from making sense of your message.
Nothing you can do to keep anyone from receiving it, that's just the nature of wireless.
Maybe you could reduce other reception some by going to dish antennas
[2.4 GHz Wi-Fi Dish Antenna With Integrated High-Gain Radio](http://"2.4 GHz Wi-Fi Dish Antenna With Integrated High-Gain Radio Shopping")
First thing to be aware of is that a connection between two nRF24s only exists for the few millisecs when one of them is actually transmitting.
The normal arrangements between two nRF24s provide a high degree of security. For anyone to snoop on your message they would have to know the channel (frequency) you are using and the address to which the message is being sent. There is a very large number of possible addresses.
If you are concerned that that is no sufficient you could also encrypt the data that you send.
In theory it is possible to create a monitoring system with some nRF24s that may be able to figure out the channel and address that you are using but it would take a very determined and experienced person to go to that much trouble. Your data would need to be very valuable indeed.
And it would certainly be possible to write programs that change channel and change address to make snooping very difficult. But doing that would probably also make debugging very difficult. :slight_smile:
...R
Simple nRF24L01+ Tutorial
I've deleted your other cross-posts @thedarknight.
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a suspension from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
