NRF24L01 wireless module
Hi my friend,
I have a problem with this module NFR24L01. I post my code:
Sender
//first included your library
#include <SPI.h>
#include <Mirf.h>
#include <nRF24L01.h>
#include <MirfHardwareSpiDriver.h>
void setup(){
    Mirf.spi = &MirfHardwareSpi;
    //Mirf.csnPin = 10; (This is optional to change the chip select pin)
    //Mirf.cePin = 9; (This is optional to change the enable pin)
    Mirf.init();
    Mirf.setTADDR((byte *)"serv1");
    Mirf.payload = 32;
    Mirf.config();
    Serial.println("Beginning ... "); // "Beginning ..." on sender, or "Listening ..." on sever (Receiver)
void loop(){
    Mirf.send((byte *) "Hello");
Receiver
#include <SPI.h>
#include <Mirf.h>
void setup(){
    Mirf.csnPin = 10; //(This is optional to change the chip select pin)
    Mirf.cePin = 9; //(This is optional to change the enable pin)
    Mirf.init();
    Mirf.payload = 32;
    Mirf.config();
void loop(){
     byte data[32]; // or int data[32];
     if(!Mirf.isSending() && Mirf.dataReady()){
          Serial.println("Got packet");
          Mirf.getData((byte *) &data);
          Serial.write(byte(data[0])); //h
          Serial.write(byte(data[1])); //e
          Serial.write(byte(data[2])); //l
          Serial.write(byte(data[3])); //l
          Serial.write(byte(data[4])); //o
          Serial.println("");
My problem is the Mirf.dataready(), because it is always 0 and its value doesn’t change.
Why?
Thanks.
Why does the receiver claim to have the same name as the sender?
uhm what do you mean?
The sender says "I'm serv1":
The receiver says "I'm serv1":
So, which one is the message addressed to "serv1" supposed to go to?
