NRF24L01+ Wireless "Shield" Module
Hi, Have you ever seen conversion boards for NRF24 radios from SPI to I2C (eventually UART), like THIS one ? I'm not as good as it is needed to get the radios to work at SPI, but they're cheap and I need them. Do you know how to use this thing ?
Nope! Seriously, just use the RF24 library by TMRh20, which uses SPI. You can install it with the library manager in the Arduino IDE.
Libraries for SPI aren't even working, I mean at all...
Pictures please? Are they not installing? Or is it a hardware problem?
I'm not a beginner. Istalled: yes, compiled: yes, wiring correct: yes, program: loaded, power: ok, serial monitor: quiet. I can't post you a picture. I gave up long time ago.
Sorry about casting aspersions on your level of ability. :P The usbtinyISP code has an option that converts USB commands to SPI, but you are using UART/I2C I would end up spending hours just seeing what happened when I sent stuff.
:p Interesting. So, I'm not a beginner but these radios are pretty much retarded. How to get them to work when nothing works ?
Use a shield? Or use a RFM69 :)
I thought you tell me something new >_<
Alright then, no other options, yay.
Yeah, basically.
PC_Master: Do you know how to use this thing ?
as you were told:
Isaac96: just use the RF24 library by TMRh20, which uses SPI.
Make shure to move the maniacbug stuff to a different location, or just delete it.
PC_Master: ...but these radios are pretty much retarded.
I have not found one place where the documentation of the chip is wrong yet.
In Germany we have an aphorism: "If a farmer can not swim, it is up to the trunks." ("Wenn der Bauer nicht schwimmen kann, liegt es an der Badehose.")
Or..".Whatever the fox cannot reach, she says they are green"
(«όσα δε φτάνει η αλεπού τα κάνει κρεμαστάρια…»)
Sour grapes
PC_Master:
Libraries for SPI aren’t even working, I mean at all…
Of course the SPI work … at least on the 12B:
Arduino + SPI + 12B
You can download the ZIP but you may need to load IDE version 1.05, 1.06, etc. It may work with newest IDE 1.6.11, but I have not tested. In any event, avoid 1.6.10 as it was warped from birth.
Ray
RF12B_GPS.zip (11.2 KB)
