NRF24L01 works with 3 slaves, but not 4?
My goal is to read sensor data (load cell data) from 4 weighing devices (slaves) on a master device using NRF24L01 modules. I used the ackPayload concept - in which the data (tare button state) from the master is sent to each slave & sensor data from each slave is sent back to the master. It worked perfectly with 3 slaves. But when I included an additional 4th slave, the output just displayed results of first transmission & stopped refreshing after - unless I change the tare button state, but it stops refreshing after as well.
With 4 slaves, except for the first transmission or change of tare button state, radio.available() is false, despite the master transmitting data to every slave. Here’s my code:
MASTER CODE
#include <RF24.h>
#include <SPI.h>
#include <nRF24l01.h>
#include <printf.h>
const byte slaveTotal = 4;
unsigned long SEND_RATE = 2000;
unsigned long currentTime;
unsigned long lastSentTime;
RF24 radio(6,7);
const byte nodeAddresses[slaveTotal][5] = {
    {'N','O','D','E','1'},
    {'N','O','D','E','2'},
    {'N','O','D','E','3'},
    {'N','O','D','E','4'}
float nodeData[slaveTotal][2] = {{1, 0}, {2, 0}, {3, 0}, {4, 0}}; // simple integer array for data from each slave node: { node_id, returned_count }
boolean tare_data = 0;
float adc_val;
float weight_val;
float totalWgt;
// TARE BUTTON
const int buttonPin = 2;
boolean buttonState;
boolean lastButtonState = LOW;
unsigned long lastDebounceTime = 0;
unsigned long debounceDelay = 50;
//SETUP
  Serial.println("[*][*][*] MASTER START [*][*][*]");
  radio.begin();
  radio.setPALevel(RF24_PA_MAX); // set power level of the radio
  radio.setDataRate(RF24_250KBPS); // set RF datarate - lowest rate for longest range capability
  radio.setChannel(0x76); // set radio channel to use - ensure all slaves match this
  radio.setRetries(4, 10);
  radio.enableAckPayload(); // enable ackpayload - enables each slave to reply with data
  pinMode(buttonPin, INPUT);
//LOOP
  currentTime = millis();
  if (currentTime - lastSentTime >= SEND_RATE){
    multiSlaveTx();
    printSlaveOutput();
/*printSlaveOutput()
 *  prints ADC & Weight value from each slave, & total weight
void printSlaveOutput(){
 Serial.print("N0 ");
 Serial.print(nodeData[0][0]);
 Serial.print(" ");
 Serial.print(nodeData[0][1]);
 Serial.print("N1 ");
 Serial.print(nodeData[1][0]);
 Serial.print(" ");
 Serial.print(nodeData[1][1]);
 Serial.print("N2 ");
 Serial.print(nodeData[2][0]);
 Serial.print(" ");
 Serial.print(nodeData[2][1]);
 Serial.print("N3 ");
 Serial.print(nodeData[3][0]);
 Serial.print(" ");
 Serial.print(nodeData[3][1]);
 totalWgt = nodeData[0][1] + nodeData[1][1] + nodeData[2][1] + nodeData[3][1];
 Serial.print(" T ");
 Serial.print(totalWgt);
/*multiSlaveTx()
 *  Transmits tare data to multiple slave & Reads load cell data from each slave
void multiSlaveTx() {
  for (byte node = 0; node < slaveTotal; node++){
    radio.openWritingPipe(nodeAddresses[node]);
    tareButtonPress();
    boolean tx_sent = radio.write( &tare_data, sizeof(tare_data) );
    if (tx_sent){
      if (radio.isAckPayloadAvailable()) {
        radio.read(&(nodeData[node]), sizeof(nodeData[node]));
  lastSentTime = millis();
/*tareButtonPress()
 *  update tare button state
void tareButtonPress(){
  int buttonReading = digitalRead(buttonPin);
  if (buttonReading != lastButtonState) {
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) > debounceDelay) {
    // if the button state has changed:
    if (buttonReading != buttonState) {
      buttonState = buttonReading;
      // only toggle the LED if the new button state is HIGH
      if (buttonState == HIGH) {
        tare_data = 1;
      } else{
        tare_data = 0;
  lastButtonState = buttonReading;
SLAVE CODE
#include <RF24.h>
#include <SPI.h>
#include <printf.h>
#include <HX711.h>
RF24 radio(6,7);
int NODE_ID = 0;
const byte nodeAddresses[4][5] = {
float nodeData[4][2] = {{1, 0}, {2, 0}, {3, 0}, {4, 0}}; // simple integer array for data from each slave node: { node_id, returned_count }
float adc_val;
float weight_val;
HX711 loadcell;
int avgSamp = 5; //No of readings taken to be averaged; Tradeoff of processing time & noise/fluctuations
const int LOADCELL_DOUT_PIN = 4;
const int LOADCELL_SCK_PIN = 5;
const long LOADCELL_OFFSET = -166945;
const long LOADCELL_DIVIDER = -20547;
//SETUP
  Serial.println("[*][*][*] SLAVE START [*][*][*]");
  radio.begin();
  radio.setChannel(0x76); // set radio channel to use - ensure it matches the target host
  radio.openReadingPipe(1, nodeAddresses[NODE_ID]);
  radio.enableAckPayload(); // enable ack payload - slave replies with data using this feature
  radio.writeAckPayload(1, &nodeData, sizeof(nodeData));
  radio.startListening();
  loadcell.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
  loadcell.set_scale(LOADCELL_DIVIDER);
  loadcell.set_offset(LOADCELL_OFFSET);
//LOOP
  if ( radio.available() ) {
    tareRead();
    loadcelldataWriteAck();
/* tareRead()
 *    read tare button press data from Master & tare loadcells;
void tareRead()
  radio.read( &tare_data, sizeof(tare_data) );
  //Serial.println(tare_data);
  if (tare_data == 1) {
    loadcell.tare();
/*loadcelldataWriteAck()
 *    Send load cell data to Master as ackPayload
void loadcelldataWriteAck()
  adc_val = loadcell.read_average(avgSamp);
  weight_val = loadcell.get_units(avgSamp);
  nodeData[NODE_ID][0] = adc_val;
  nodeData[NODE_ID][1] = weight_val;
  radio.writeAckPayload(1, &(nodeData[NODE_ID]), sizeof(nodeData[NODE_ID]));
My code is based on Ben Fraser’s & Robin2’s codes:
I appreciate any help, thank you!
If you are having a wireless problem then I suggest you start with the simplest possible program that just sends (and receives) fixed data. In other words leave out all the measurement stuff.
If it was my problem I would use the multi-example in my Simple nRF24L01+ Tutorial and I would not do anything until it works with the required number of slaves. When that worked I would gradually extend the code to deal with the extra stuff testing after every change.
Separately ...
I can see why you have this array in the master
but I would not have it in my slaves. I would just have a simple 2 element array in the slaves to make things as simple as possible
float nodeData[2] = {1, 0};
What is the purpose of putting
    tareButtonPress();
in the middle of the wireless function multiSlaveTx() ?
To my mind it has no business being there. Keep things simple.
...R
With four clients and a constant packet content all but the very first packets will be considered duplicate,
because the internal ID counter is only two bits long.
Add a counter to the tare packet that gets incremented after each successful send,
that way the crc will be different.
Thanks for your reply Robin2 & Whandall, greatly appreciate your help!
So, I redid my code as advised by Robin2 and it works! Was trying hard not to start from scratch (thinking I would spend more time) but I've been debugging for days. Now, it's definitely cleaner, simpler, faster & way easier to debug.
Previously, I had this array in the master so that I could add the total weight values together by indexing them. Just copied them in the slave without thinking.
Now, I'm just adding the weight values in the for loop in send() this way. Don't know if it's the best way, but it works!
totalWgt += ackData[1];
