nRF24L01P+PA+LNA always receiving
So I'm using an nRF24L01P+PA+LNA with an Arduino Nano and the RF24 library. I've checked the wiring multiple times and verified it is correct. However, when I check radio.available() it always returns true even if there's no other transmitter. It will only return false when I unplug the transmitter from the nano. I am only using the 3.3v pin on the nano at the moment because I do not have the 5v breakout adapter yet. Could that be the cause for this or did I miss something else?
Here's the code for the receiver:
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
// define the pins
#define CE_PIN   9
#define CSN_PIN 10
// Create a Radio
RF24 radio(CE_PIN, CSN_PIN);
// The tx/rx address
const byte rxAddr[6] = "00001";
  while(!Serial);
  Serial.println("NRF24L01P Receiver Starting...");
  radio.begin();
  radio.setPALevel(RF24_PA_MIN);   // RF24_PA_MIN ,RF24_PA_LOW, RF24_PA_HIGH, RF24_PA_MAX
  radio.setDataRate( RF24_250KBPS ); // RF24_250KBPS, RF24_1MBPS, RF24_2MBPS
  radio.openReadingPipe(0, rxAddr);
  radio.startListening();
  if (radio.available())
    Serial.println("Received Message: ");
The 3.3volt supply of a Nano is extracted from the USB<>Serial chip, and 30mA draw is about max.
It will not reliably power a regular rf24 let alone the high powered ones. Try putting a 10uF cap across the supply to the radio, as close as possible to the radio. Try using a 2 AA cell battery pack to power the rf24 (connect the battery ground to Arduino ground). I use homemade adapters with a dedicated 3.3V regulator for each radio (probably like the ones that you have on order).
A couple of other things that helped me:
If using the high powered radios make sure to separate them by a few meters. They may not work too close together. Try the lower power settings.
Reset the radios by cycling power to them after uploading new code. I have found that to help. They do not reset with the Arduino.
There is a lot of good information in the simple rf24 tutorial by Robin2.
If you post the transmit code I can test the code with 2 Unos and rf24 (low power) modules.
Don't you need to read the data coming in?
Something like this:
     char incoming[32];
     radio.read( &incoming, sizeof(incoming));
     Serial.print("Received Message: ");
     Serial.println(incoming);
