nRF24L01p+ PA+ LNA+ V3.1 help needed (RF Module)
I have these set up and talking to each other. I can tell by the current draw that the transmitter is operating in the low power mode. I cannot find setup code to change to high power. Anyone use these high power units? Larry
Are you talking about 4 devices connected together?
Have you links to the datasheets for them?
...R
Just one way from a transmitter to a receiver. I don't understand how to change output levels of the transmitter or the data rate. Larry
Neither do I since you didn't bother to provide links to datasheets or explain what each of the 4 items you mention is.
...R
Its a transceiver rated with a 1000 meter range, Datasheet HERE. Its the same one I was going to get but it costs a lot of money.
trotterlg: I cannot find setup code to change to high power.
I haven't used the amplified versions, but I use the non-amplified versions with Maniacbug's RF24 library. This provides an API to set the power level, data rate, retry count/interval and so on. Perhaps the amplified version works the same way?
