Hello,
Im using the Getting Started Script,
08:58:32.412 -> SPI Speedz = 10 Mhz
08:58:32.412 -> STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
08:58:32.412 -> RX_ADDR_P0-1 = 0x65646f4e31 0x65646f4e32
08:58:32.412 -> RX_ADDR_P2-5 = 0xc3 0xc4 0xc5 0xc6
08:58:32.412 -> TX_ADDR = 0x65646f4e31
08:58:32.412 -> RX_PW_P0-6 = 0x04 0x04 0x04 0x04 0x04 0x04
08:58:32.412 -> EN_AA = 0x3f
08:58:32.412 -> EN_RXADDR = 0x02
08:58:32.412 -> RF_CH = 0x4c
08:58:32.412 -> RF_SETUP = 0x03
08:58:32.412 -> CONFIG = 0x0f
08:58:32.412 -> DYNPD/FEATURE = 0x00 0x00
08:58:32.412 -> Data Rate = 1 MBPS
08:58:32.444 -> Model = nRF24L01+
08:58:32.444 -> CRC Length = 16 bits
08:58:32.444 -> PA Power = PA_LOW
08:58:32.444 -> ARC = 0
All modules print the radio.printDetails(); like that wich i think is ok.
I have 3 NRF24 modules with antenas and 2 without, they all work while connected to te ESP8266s but i cant make any of them work with either my Arduino UNO or any of my 4 Arduino Pro Mini, all the modules are probably clones do to its price cuz im from Argentina.
The modules work perfect con the ESPs without extra PSU or capacitor or anything i just connect them to 3.3 of the board and they work like a charm but i have tried Externals PSUs and Capacitor on each of the othersd with the arduinos and i couldnt make any single one of them work.
08:58:32.444 -> SPI Frequency = 10 Mhz
08:58:32.444 -> Channel = 76 (~ 2476 MHz)
08:58:32.444 -> RF Data Rate = 1 MBPS
08:58:32.444 -> RF Power Amplifier = PA_LOW
08:58:32.444 -> RF Low Noise Amplifier = Enabled
08:58:32.444 -> Address Length = 5 bytes
08:58:32.444 -> Static Payload Length = 4 bytes
08:58:32.444 -> Auto Retry Delay = 1500 microseconds
08:58:32.476 -> Auto Retry Attempts = 15 maximum
08:58:32.476 -> Packets lost on
08:58:32.476 -> current channel = 0
08:58:32.476 -> Retry attempts made for
08:58:32.476 -> last transmission = 0
08:58:32.476 -> Multicast = Disabled
08:58:32.476 -> Custom ACK Payload = Disabled
08:58:32.476 -> Dynamic Payloads = Disabled
08:58:32.476 -> Auto Acknowledgment = Enabled
08:58:32.476 -> Primary Mode = RX
08:58:32.476 -> TX address = 0x65646f4e31
08:58:32.476 -> pipe 0 (closed) bound = 0x65646f4e31
08:58:32.476 -> pipe 1 ( open ) bound = 0x65646f4e32
08:58:32.518 -> pipe 2 (closed) bound = 0xc3
08:58:32.518 -> pipe 3 (closed) bound = 0xc4
08:58:32.518 -> pipe 4 (closed) bound = 0xc5
08:58:32.518 -> pipe 5 (closed) bound = 0xc6
This is the prety details just in case.
Ive tried every possible Data Rate Speed also Min to Max Power and it made no diference.
I configured the ESP8266 with the exact same code on the Arduino IDE .
Im using Arduino IDE 2.3.2 and the RF24 Library 1.4.9, i already reinstalled the library 4 times including downloading the ZIP from GitHub and intalling it that way.
Im completly out of ideas.
Thanks for anyone that ocn offer advice.
The code im running.
* See documentation at https://nRF24.github.io/RF24
* See License information at root directory of this library
* Author: Brendan Doherty (2bndy5)
* A simple example of sending data from 1 nRF24L01 transceiver to another.
* This example was written to be used on 2 devices acting as "nodes".
* Use the Serial Monitor to change each node's behavior.
#include <SPI.h>
#include "printf.h"
#include "RF24.h"
#define CE_PIN 9
#define CSN_PIN 10
// instantiate an object for the nRF24L01 transceiver
RF24 radio(CE_PIN, CSN_PIN);
// Let these addresses be used for the pair
uint8_t address[][6] = { "1Node", "2Node" };
// It is very helpful to think of an address as a path instead of as
// an identifying device destination
// to use different addresses on a pair of radios, we need a variable to
// uniquely identify which address this radio will use to transmit
bool radioNumber = 1; // 0 uses address[0] to transmit, 1 uses address[1] to transmit
// Used to control whether this node is sending or receiving
bool role = false; // true = TX role, false = RX role
// For this example, we'll be using a payload containing
// a single float number that will be incremented
// on every successful transmission
float payload = 0.0;
while (!Serial) {
// some boards need to wait to ensure access to serial over USB
// initialize the transceiver on the SPI bus
if (!radio.begin()) {
Serial.println(F("radio hardware is not responding!!"));
while (1) {} // hold in infinite loop
// print example's introductory prompt
Serial.println(F("RF24/examples/GettingStarted"));
// To set the radioNumber via the Serial monitor on startup
Serial.println(F("Which radio is this? Enter '0' or '1'. Defaults to '0'"));
while (!Serial.available()) {
// wait for user input
char input = Serial.parseInt();
radioNumber = input == 1;
Serial.print(F("radioNumber = "));
Serial.println((int)radioNumber);
// role variable is hardcoded to RX behavior, inform the user of this
Serial.println(F("*** PRESS 'T' to begin transmitting to the other node"));
// Set the PA Level low to try preventing power supply related problems
// because these examples are likely run with nodes in close proximity to
// each other.
//radio.setPALevel(RF24_PA_MAX); // RF24_PA_MAX is default.
//radio.setAutoAck(false);
//radio.setDataRate (RF24_250KBPS);
radio.setPALevel(0);
// save on transmission time by setting the radio to only transmit the
// number of bytes we need to transmit a float
radio.setPayloadSize(sizeof(payload)); // float datatype occupies 4 bytes
// set the TX address of the RX node into the TX pipe
radio.openWritingPipe(address[radioNumber]); // always uses pipe 0
// set the RX address of the TX node into a RX pipe
radio.openReadingPipe(1, address[!radioNumber]); // using pipe 1
// additional setup specific to the node's role
if (role) {
radio.stopListening(); // put radio in TX mode
radio.startListening(); // put radio in RX mode
// For debugging info
printf_begin(); // needed only once for printing details
radio.printDetails(); // (smaller) function that prints raw register values
radio.printPrettyDetails(); // (larger) function that prints human readable data
} // setup
if (role) {
// This device is a TX node
unsigned long start_timer = micros(); // start the timer
bool report = radio.write(&payload, sizeof(float)); // transmit & save the report
unsigned long end_timer = micros(); // end the timer
if (report) {
Serial.print(F("Transmission successful! ")); // payload was delivered
Serial.print(F("Time to transmit = "));
Serial.print(end_timer - start_timer); // print the timer result
Serial.print(F(" us. Sent: "));
Serial.println(payload); // print payload sent
payload += 0.01; // increment float payload
Serial.println(F("Transmission failed or timed out")); // payload was not delivered
// to make this example readable in the serial monitor
delay(1000); // slow transmissions down by 1 second
// This device is a RX node
uint8_t pipe;
if (radio.available(&pipe)) { // is there a payload? get the pipe number that recieved it
uint8_t bytes = radio.getPayloadSize(); // get the size of the payload
radio.read(&payload, bytes); // fetch payload from FIFO
Serial.print(F("Received "));
Serial.print(bytes); // print the size of the payload
Serial.print(F(" bytes on pipe "));
Serial.print(pipe); // print the pipe number
Serial.print(F(": "));
Serial.println(payload); // print the payload's value
} // role
if (Serial.available()) {
// change the role via the serial monitor
char c = toupper(Serial.read());
if (c == 'T' && !role) {
// Become the TX node
role = true;
Serial.println(F("*** CHANGING TO TRANSMIT ROLE -- PRESS 'R' TO SWITCH BACK"));
} else if (c == 'R' && role) {
// Become the RX node
role = false;
Serial.println(F("*** CHANGING TO RECEIVE ROLE -- PRESS 'T' TO SWITCH BACK"));
} // loop
