I am using a seeed nRF52840 (link)
and trying to communicate with a senseair K33 CO2 sensor
Here is my code that works for about 2 minutes, then seems to halt randomly. It will stop printing to the console until I remove power and plug back in.
#include <Wire.h>
#include "Adafruit_TinyUSB.h"
int co2Addr = 0x68;
while(!Serial)
delay(5);
Serial.println("Program Started");
Wire.setClock(100000); // Set I2C clock speed to 100 kHz
Wire.begin();
double readCo2() {
Serial.println("Starting readCo2() function");
int co2_value = 0;
// Clear I2C bus
Wire.beginTransmission(co2Addr);
byte clearBusResult = Wire.endTransmission();
Serial.print("Clear bus result: ");
Serial.println(clearBusResult);
delay(5); // Wait a bit before sending the actual command
Wire.write(0x22); // Command to read from RAM
Wire.write(0x00); // High byte of number of bytes to read
Wire.write(0x08); // Start address (high byte of CO2 value)
Wire.write(0x2A); // Checksum for the write sequence
byte transmissionResult = Wire.endTransmission();
Serial.print("End transmission result: ");
Serial.println(transmissionResult);
delay(20); // Wait for the sensor to process the command
Serial.println("Requesting data from sensor");
Wire.requestFrom(co2Addr, 4);
byte buffer[4] = {0, 0, 0, 0};
if (Wire.available() == 4) {
Serial.println("Reading data from buffer");
for (int i = 0; i < 4; i++) {
buffer[i] = Wire.read();
Serial.print("Buffer[");
Serial.print(i);
Serial.print("]: ");
Serial.println(buffer[i], HEX);
co2_value = (buffer[1] << 8) | buffer[2];
Serial.print("CO2 Value: ");
Serial.println(co2_value);
byte sum = buffer[0] + buffer[1] + buffer[2];
Serial.print("Calculated checksum: ");
Serial.println(sum, HEX);
Serial.print("Received checksum: ");
Serial.println(buffer[3], HEX);
if (sum == buffer[3]) {
Serial.println("Checksum valid");
return (double)co2_value;
Serial.println("Checksum invalid");
return (double)-1;
Serial.println("Insufficient data received");
return (double)-1; // Communication failed
unsigned long currentTime = millis();
Serial.print("Time since start: ");
Serial.print(currentTime / 1000); // Convert milliseconds to seconds
Serial.println(" seconds");
double co2Value = readCo2();
if (co2Value >= 0) {
Serial.print("CO2: ");
Serial.println(co2Value);
else {
Serial.println("Checksum failed / Communication failure");
delay(2000);
I have the 5V rail from the nRF powering the CO2 sensor, and then i2c lines connected as expected on pins 4 and 5.
Any suggestions why it seems to "lock up" ?
Blockquote
