EDIT: Debug code is in second post. Cant post the error code as it is over 9000 characters (about 430 lines) so it can only be viewed on the pastebin link sorry
So I have two nRF905 transceivers. I've installed the library and am trying to run/verify some of the example codes and keep getting flooded with error messages & I just don't know enough about programming to decipher the issue(s)
https://github.com/zkemble/nRF905
^^^^ Library I installed/downloaded ^^^^
^^^^ Debug code (from example) ^^^^
^^^^ Debug error messages ^^^^
So I have added the library to the IDE & restarted it. I am using the C++ examples and not the C examples.
Any help is much appreciated.
See the "how to use this forum-please read" sticky to see how to post code and errors meaasages so that we don't have to download them. See #7.
Cheers!
The debug Code
* Project: nRF905 AVR/Arduino Library/Driver (Debug example)
* Author: Zak Kemble, contact@zakkemble.co.uk
* Copyright: (C) 2017 by Zak Kemble
* License: GNU GPL v3 (see License.txt)
* Web: http://blog.zakkemble.co.uk/nrf905-avrarduino-librarydriver/
* Read configuration registers
* 7 -> CE
* 8 -> PWR
* 9 -> TXE
* 4 -> CD
* 3 -> DR
* 2 -> AM
* 10 -> CSN
* 12 -> SO
* 11 -> SI
* 13 -> SCK
#include <nRF905.h>
#include <nRF905_defs.h>
#define RXADDR 0xFE4CA6E5 // Address of this device
// Start up
nRF905_init();
// Set address of this device
nRF905_setListenAddress(RXADDR);
// Put into receive mode
nRF905_RX();
Serial.println(F("Started"));
byte regs[NRF905_REGISTER_COUNT];
nRF905_getConfigRegisters(regs);
Serial.print(F("Raw: "));
byte dataValid = 0;
for(byte i=0;i<NRF905_REGISTER_COUNT;i++)
Serial.print(regs[i]);
Serial.print(F(" "));
if(regs[i] == 0xFF || regs[i] == 0x00)
dataValid++;
// Registers were all 0xFF or 0x00, this is probably bad
if(dataValid >= NRF905_REGISTER_COUNT)
Serial.println(F("All registers read as 0xFF or 0x00! Is the nRF905 connected correctly?"));
return;
char* str;
byte data;
uint16_t channel = ((uint16_t)(regs[1] & 0x01)<<8) | regs[0];
uint32_t freq = (422400UL + (channel * 100UL)) * (1 + ((regs[1] & ~NRF905_MASK_BAND) >> 1));
Serial.print(F("Channel: "));
Serial.println(channel);
Serial.print(F("Freq: "));
Serial.print(freq);
Serial.println(F("KHz"));
Serial.print(F("Auto retransmit: "));
Serial.println(!!(regs[1] & ~NRF905_MASK_AUTO_RETRAN));
Serial.print(F("Low power RX: "));
Serial.println(!!(regs[1] & ~NRF905_MASK_LOW_RX));
// TX power
data = regs[1] & ~NRF905_MASK_PWR;
switch(data)
case NRF905_PWR_n10:
data = -10;
case NRF905_PWR_n2:
data = -2;
case NRF905_PWR_6:
data = 6;
case NRF905_PWR_10:
data = 10;
default:
data = -127;
Serial.print(F("TX Power: "));
Serial.print((signed char)data);
Serial.println(F("dBm"));
// Freq band
data = regs[1] & ~NRF905_MASK_BAND;
switch(data)
case NRF905_BAND_433:
str = (char*)"433";
default:
str = (char*)"868/915";
Serial.print(F("Band: "));
Serial.print(str);
Serial.println(F("MHz"));
Serial.print(F("TX Address width: "));
Serial.println(regs[2] >> 4);
Serial.print(F("RX Address width: "));
Serial.println(regs[2] & 0x07);
Serial.print(F("RX Payload size: "));
Serial.println(regs[3]);
Serial.print(F("TX Payload size: "));
Serial.println(regs[4]);
Serial.print(F("RX Address [0]: "));
Serial.println(regs[5]);
Serial.print(F("RX Address [1]: "));
Serial.println(regs[6]);
Serial.print(F("RX Address [2]: "));
Serial.println(regs[7]);
Serial.print(F("RX Address [3]: "));
Serial.println(regs[8]);
Serial.print(F("RX Address: "));
Serial.println(((unsigned long)regs[8]<<24 | (unsigned long)regs[7]<<16 | (unsigned long)regs[6]<<8 | (unsigned long)regs[5]));
// CRC mode
data = regs[9] & ~NRF905_MASK_CRC;
switch(data)
case NRF905_CRC_16:
str = "16bit";
case NRF905_CRC_8:
str = "8bit";
default:
str = "Disabled";
Serial.print(F("CRC Mode: "));
Serial.println(str);
// Xtal freq
data = regs[9] & ~NRF905_MASK_CLK;
switch(data)
case NRF905_CLK_4MHZ:
data = 4;
case NRF905_CLK_8MHZ:
data = 8;
case NRF905_CLK_12MHZ:
data = 12;
case NRF905_CLK_16MHZ:
data = 16;
case NRF905_CLK_20MHZ:
data = 20;
default:
data = 0;
Serial.print(F("Xtal freq: "));
Serial.print(data);
Serial.println("MHz");
// Clock out freq
data = regs[9] & ~NRF905_MASK_OUTCLK;
switch(data)
case NRF905_OUTCLK_4MHZ:
str = "4MHz";
case NRF905_OUTCLK_2MHZ:
str = "2MHz";
case NRF905_OUTCLK_1MHZ:
str = "1MHz";
case NRF905_OUTCLK_500KHZ:
str = "500KHz";
default:
str = "Disabled";
Serial.print(F("Clock out freq: "));
Serial.println(F("---------------------"));
