when using NRFLITE LIBRARY of dparson my LED that blinks is very DIM using Arduino R3 /pro mini hardware.
I tested same program with RF24 library on those hardware and the led blink program is bright as should be.
could it be anything to do with the library itself?
#include <SPI.h>
#include <NRFLite.h>
const static uint8_t RADIO_ID = 0; // Our radio's id. The transmitter will send to this id.
const static uint8_t PIN_RADIO_CE = 9;
const static uint8_t PIN_RADIO_CSN = 10;
const uint8_t LED[] = {2, 3, 4};
uint8_t myArray[1];
struct RadioPacket // Any packet up to 32 bytes can be sent.
uint8_t FromRadioId;
uint32_t OnTimeMillis;
uint32_t FailedTxCount;
NRFLite _radio(Serial);
RadioPacket _radioData;
if (!_radio.init(RADIO_ID, PIN_RADIO_CE, PIN_RADIO_CSN, NRFLite::BITRATE250KBPS, 50))
Serial.println("Cannot communicate with radio");
while (1); // Wait here forever.
_radio.printDetails();
By default, 'init' configures the radio to use a 2MBPS bitrate on channel 100 (channels 0-125 are valid).
Both the RX and TX radios must have the same bitrate and channel to communicate with each other.
You can assign a different bitrate and channel as shown below.
_radio.init(RADIO_ID, PIN_RADIO_CE, PIN_RADIO_CSN, NRFLite::BITRATE250KBPS, 0)
_radio.init(RADIO_ID, PIN_RADIO_CE, PIN_RADIO_CSN, NRFLite::BITRATE1MBPS, 75)
_radio.init(RADIO_ID, PIN_RADIO_CE, PIN_RADIO_CSN, NRFLite::BITRATE2MBPS, 100) // THE DEFAULT
if (_radio.hasData())
_radio.readData(&myArray); // Note how '&' must be placed in front of the variable name.
//Light up the correct LEDs
for (uint8_t j = 1; j <= 3; j++)
if (myArray[0] == j) {
digitalWrite(LED[j - 1], HIGH);
Serial.println(j);
if (myArray[0] == 0) {
digitalWrite(LED[j - 1], LOW);
Serial.println("low");
