NS73 Question, multiple frequencies
Hi, first of all I do not fully understand how you do program the NS73 to transmit at a certain frequency, but I was wondering if it is possible to either (1) transmit at multiple frequencies at a time or (2) pulse different frequencies to transmit very fast so maybe you create an illusion of transmitting several frequencies at a time.
Are either of these possible?
If not does anyone know how it would be possible to achieve this with a different fm module maybe?
Thanks a lot,
Adam
No.
No No No, this will create a sort of interference that will probably spread over the whole band. Actually you will probably find that it will no be able to change that fast anyway.
Best you could do is to use two modules.
Hmm, well maybe you could help me with this then?
I am looking to transmit short range, wide band radio. Attempting to transmit over the whole FM band (I realize this is most probably illegal). Is there anything out there that can provide something close to this?
Thanks,
Adam
Nothing probable about it, this is defiantly illegal.
You could do this with wide bandwidth modulation or with frequency agile hopping. However as it is illegal I don't think any one will sell kits to do this sort of thing. It is the sort of thing you have to design from scratch.
What are you actually trying to achieve, is it jamming FM reception?
Have a look at the radio ham community.
I am designing a device which reverses the role of traffic noise pollution.
So a person standing on the corner of a busy street, exposed to a high volumes of noise pollution, holds this device which transmits "annoying" sounds over the whole FM band which would hopefully hijack the cars radios while they are in range.
That's why I want to transmit over the whole band so you can be affected every car in range that is listening to FM radio.
OK so defiantly in the illegal and get yourself arrested camp here. Not a illegal but discreet so might get away with it.
Simply put you need to modulate wide band noise, probably from a diode. Most transmitters would put a limit on the FM modulation width so a simple free running oscillator should do.
However, you need a more powerful transmitter than that which you posted. That transmitter, despite what the web site says, would only over power a received signal for about one meter.
Would you mind expanding that? What exactly would a free running oscillator be?
Thanks again for the help.
Is this free running oscillator similar to a "blocking oscillator"?
And this would help in what manner? Are you simply attempting to build something "just in time" for Defcon? What is the ultimate purpose of this project?
You want to really get away or somehow reduce such noise pollution? A) get your own car, B) buy some earplugs, C) move out of the city
Tilt at windmills, much, Don?
:slight_smile:
It's simply a media art project (for graduate school at SUNY at Buffalo) which takes a playful approach at commenting on an issue which affects social relationships between vehicle and pedestrian.
Well if you call playfull breaking the law and risking getting arrested then be my guest. I would have thought the indecent at Chicago Air port, where a girl in a tee shirt with LEDs got not only arrested but also prostituted for committing a terrorist hoax might serve to say that officialdom has no sense of humour in your country.
It is an oscillator whose frequency is simply defined by the values of it's inductor and capacitor. This is usually not too stable due to temperature variations and mechanical stresses. That it it is not locked to anything be it a crystal, resonator or phase locked loop.
A blocking oscillator is one way of how you make an oscillator, there are lots of others.
I'm not too sure where an Arduino comes into this project, maybe you would be better off looking at the Ham radio sites.
OT, what was all that about, then? I missed that item of news
Sorry it was Boston.
