NTC and arduino P.I.D. SSR
Greetings to all !
If I may please ask for your advice on the following project:
I have 2 ΝΤC thermistors @ 10ΚΩ at 25C with B constant 3950K (they can read up to 200C) and wish to control two SSRs on the output of which, I will connect 2 heating elements (one on each), so two input temperatures independent one from the other, and two output channels again one separate from the other.
I would like to be able to read set and current values of the temperatures on a small LCD screen (maybe 2 lines?) and to be able to create a very simple gui on the board's LAN address to adjust settings from there, e.g. set channel 1 from 70C to 130C.
What would be (if possible) the smallest Arduino to use as P.I.D. controller based on the above with wifi capabilities? I have seen some libraries online but would like to ask the community for hardware connection opinions. Would I be able to do that on Arduino uno for example or any other? (Where I will install the electronics I have limited space)
Thank you in advance!
Any Arduino would do. Is PID really needed? Why not switch power on and off at the temperature set? What is the accurazy, the step responce You need?
If you want WiFi on board, look at the ESP8266 based boards; the WeMOS D1 Mini is probably the smallest around. NodeMCU isn't much bigger, though.
Mind that to read 70-130°C with reasonable accuracy you have to reduce the series resistor value to 1-2k, the value of your thermistor at around 100°C. You're probably better off with a 50k or 100k nominal NTC for those temperatures, as those low resistance values and consequently high currents cause self heating.
