NTC sensor reading ok on Arduino Nano but not on Arduino Uno
Hi , everyone!
Today i wanted to implent an NTC Temperature Sensor in one of my projects so i followed the example at this site : http://garagelab.com/profiles/blogs/tutorial-using-ntc-thermistors-with-arduino
I did the first kind of circuit showed on the page.
My sketch is looking as this :
#include <Thermistor.h>
Thermistor temp(0);
int temperature = temp.getTemp();
Serial.print("The sensor temperature is: ");
Serial.print(temperature);
Serial.println("*C");
I then ran the sketch on my Arduino Nano and everything went fine, it showed correct temperature.
I so decided to implent it in my other Arduino, Arduino Uno rev.3
The temperature readings were all wrong not so much , just 21 °C more than it should have been!
Now, my question is : how can that be? I made the same connections (even did it over and over again for three times) but the readings on the Arduino Uno are always wrong.
I also tried changing the AnalogInput from 0 to 1 but the readings were always wrong.
I just can’t come up on how can this happen! I then tried it over on the Nano again, and on the Nano it works like a charm!
My Arduino Uno has other connections and resistors for other purposes, may they affect in some way?
How could i check out what’s going wrong?
I also tried to use different GND connection but nothing changes.
Please help!
marcomaroso: My Arduino Uno has other connections and resistors for other purposes, may they affect in some way? How could i check out what's going wrong?
Unplug them.
marcomaroso: Thermistor temp(0);
Never rely on side effects which may work in some cases, with some board settings or some IDE versions!
I don't know your thermistor library, but as I can see nowhere an analog pin reference, I think you reference A0 as 0.
So perhaps better use the correct pin number constant A0 if you want the NTC value reading from the A0 pin:
Thermistor temp(A0);
jurs: Never rely on side effects which may work in some cases, with some board settings or some IDE versions!
Thanks bud,
i will try that too even if i seem to recall i had already tried that too but i'll double check it.
Martin-X: Unplug them.
I tried to unplug them but result didn't change.
marcomaroso: I tried to unplug them but result didn't change.
Do you have a multimeter to measure voltage?
Measure the 5V to GND voltage with your Nano: Result? Measure the 5V to GND voltage with your UNO: Result?
Measure the A0 to GND voltage with your Nano: Result? Measure the A0 to GND voltage with your UNO: Result?
Have you go a bypass capacitor on the A0 to gnd? 0.1uF will do.
Tom..... :)
