NTC Time Library - UDP problem
Hello,
I want to write a library at the time from a Network Time Protocol (NTP) time servers get.
The first problem I have is the inizialieserung of the "EthernetUDP" object in my NTC_Time.h file.
#ifndef NTC_Time_h
#define NTC_Time_h
#include "Arduino.h"
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
class NTC_Time{
  private:
    EthernetUDP Udp;
  public:
    NTC_Time(byte ipNTCServer[4], byte pTimeZone); //my constructor
#endif
If I leave the NTC_Time.cpp empty, I get no error.
If I write something in the NTC_Time.cpp I get the following error.
#include "NTC_Time.h"
NTC_Time::NTC_Time(byte ipNTCServer[4], byte pTimeZone){
In file included from NTC_Time.cpp:1:
NTC_Time.h:11: error: 'EthernetUDP' does not name a type
Do you have any idea what I could do to make it work?
The second problem is, I do not know how to pass IP addresses to a function / libraries.
Thanks!
PS: I am a newbie in things like libraries / classes.
Move these from the library code and include them in your sketch code.
#include <SPI.h>
Have you gotten NTP to work ok in a sketch?
Thx it work :slight_smile:
Yes, I have this one:
If you are building a library, may I suggest adding this.
It is a way to get the ip of a NTP server with dns from pool.ntp.org.
Thank you for the help.
Now I have everything. :slight_smile:
I wish I did...
