NTP / SNTP request
Hello,
I have an Arduino DUE R3 and a new Ethernet Shield 2.
I’m trying to get time of my ntp server but without success.
My code:
 * Time_NTP.pde
 * Example showing time sync to NTP time source
 * This sketch uses the Ethernet library
#include <Time.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <SPI.h>
byte mac[] = {0x90,0xA2,0xDA,0x10,0x04,0xFB};
IPAddress ip(192,168,89,11);
IPAddress gateway(192,168,89,254);
IPAddress subnet(255,255,255,0);
IPAddress dnsServer(192,168,1,210);
// NTP Servers:
IPAddress timeServer(192,168,1,210); // dst ntp server
const int timeZone = 1;     // Central European Time
EthernetUDP Udp;
unsigned int localPort = 123;  // local port to listen for UDP packets
  while (!Serial) ; // Needed for Leonardo only
  delay(250);
  Serial.println("TimeNTP Example");
//    Ethernet.begin(mac);
    Ethernet.begin(mac, ip);
//  Ethernet.begin(mac, ip, dns);
//  Ethernet.begin(mac, ip, dnsServer, gateway);
//  Ethernet.begin(mac, ip, dns, gateway, subnet);
  Serial.print("IP number assigned is ");
  Serial.println(Ethernet.localIP());
  Udp.begin(localPort);
  Serial.println("waiting for sync");
  setSyncProvider(getNtpTime);
time_t prevDisplay = 0; // when the digital clock was displayed
  if (timeStatus() != timeNotSet) {
    if (now() != prevDisplay) { //update the display only if time has changed
      prevDisplay = now();
      digitalClockDisplay();
void digitalClockDisplay(){
  // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.print(" ");
  Serial.print(day());
  Serial.print(" ");
  Serial.print(month());
  Serial.print(" ");
  Serial.print(year());
void printDigits(int digits){
  // utility for digital clock display: prints preceding colon and leading 0
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
/*-------- NTP code ----------*/
const int NTP_PACKET_SIZE = 150; // NTP time is in the first 48 bytes of message
byte packetBuffer[NTP_PACKET_SIZE]; //buffer to hold incoming & outgoing packets
time_t getNtpTime()
  while (Udp.parsePacket() > 0) ; // discard any previously received packets
  Serial.println("Transmit NTP Request");
  sendNTPpacket(timeServer);
  uint32_t beginWait = millis();
  while (millis() - beginWait < 1500) {
    int size = Udp.parsePacket();
    if (size >= NTP_PACKET_SIZE) {
      Serial.println("Receive NTP Response");
      Udp.read(packetBuffer, NTP_PACKET_SIZE);  // read packet into the buffer
      unsigned long secsSince1900;
      // convert four bytes starting at location 40 to a long integer
      secsSince1900 =  (unsigned long)packetBuffer[40] << 24;
      secsSince1900 |= (unsigned long)packetBuffer[41] << 16;
      secsSince1900 |= (unsigned long)packetBuffer[42] << 8;
      secsSince1900 |= (unsigned long)packetBuffer[43];
      return secsSince1900 - 2208988800UL + timeZone * SECS_PER_HOUR;
  Serial.println("No NTP Response :-(");
  return 0; // return 0 if unable to get the time
// send an NTP request to the time server at the given address
void sendNTPpacket(IPAddress &address)
  // set all bytes in the buffer to 0
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  // Initialize values needed to form NTP request
  // (see URL above for details on the packets)
  packetBuffer[0] = 0b11100011;   // LI, Version, Mode
  packetBuffer[1] = 0;     // Stratum, or type of clock
  packetBuffer[2] = 6;     // Polling Interval
  packetBuffer[3] = 0xEC;  // Peer Clock Precision
  // 8 bytes of zero for Root Delay & Root Dispersion
  packetBuffer[12]  = 49;
  packetBuffer[13]  = 0x4E;
  packetBuffer[14]  = 49;
  packetBuffer[15]  = 52;
  // all NTP fields have been given values, now
  // you can send a packet requesting a timestamp:
  Udp.beginPacket(address, 123); //NTP requests are to port 123
  Udp.write(packetBuffer, NTP_PACKET_SIZE);
  Udp.endPacket();
it’s possible that my server only runs on SNTP?
How do I contact for NTP instead of NTP?
What happens when you run it? What is the output?
jot4p:
 * Time_NTP.pde
File extension .PDE was used with Arduino boards in a short time after the age of the dinosaurs ended, I think.
Perhaps use a more recent code.
Hello
jot4p,
the UDP.begin should be with Port 2390, not with 123. You send only your request to Port 123.
UDP.begin(2390);
In my sketch its pretty good...
regards
Dieter
jurs:
"Time_NTP.pde"
this is only a comment :slight_smile: :slight_smile:
cerebellum:
Hello
jot4p,
UDP.begin(2390);
regards
Dieter
Thanks, but not work for me! :confused:
Done! :slight_smile:
Final code here:
#include <Time.h>
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
const int timeZone = 0;     // UK, PORTUGAL
EthernetUDP Udp;
unsigned int localPort = 8888;  // local port to listen for UDP packets
  delay(250);
  if (Ethernet.begin(mac) == 0) {
    // no point in carrying on, so do nothing forevermore:
    while (1) {
      Serial.println("Failed to configure Ethernet using DHCP");
      delay(10000);
  Serial.print("IP number assigned by DHCP is ");
Serial.println(hour()*100);
Serial.println(minute());
  Serial.print(" ");
  Serial.print(" ");
  Serial.print(" ");
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
const int NTP_PACKET_SIZE = 48; // NTP time is in the first 48 bytes of message
time_t getNtpTime()
  Udp.endPacket();
