Hello, I'm new here
I got this piece of code that I want to used for accurate time reading on my arduino uno based on NTP server.
I use ENC28J60 as network interface, UIPEthernet.h library, and Time.h library.
* Time_NTP.pde
* Example showing time sync to NTP time source
* This sketch uses the Ethernet library
#include <Time.h>
#include <UIPEthernet.h> // Used for Ethernet
#include <UIPUdp.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// NTP Servers:
//IPAddress timeServer(132, 163, 4, 101); // time-a.timefreq.bldrdoc.gov
IPAddress timeServer(81,168,77,149); //
// IPAddress timeServer(132, 163, 4, 103); // time-c.timefreq.bldrdoc.gov
const int timeZone = 2;Â Â // Central European Time
//const int timeZone = -5;Â // Eastern Standard Time (USA)
//const int timeZone = -4;Â // Eastern Daylight Time (USA)
//const int timeZone = -8;Â // Pacific Standard Time (USA)
//const int timeZone = -7;Â // Pacific Daylight Time (USA)
EthernetUDP Udp;
unsigned int localPort = 8888;Â // local port to listen for UDP packets
 while (!Serial) ; // Needed for Leonardo only
 delay(250);
 Serial.println("TimeNTP Example");
 if (Ethernet.begin(mac) == 0) {
  // no point in carrying on, so do nothing forevermore:
  while (1) {
   Serial.println("Failed to configure Ethernet using DHCP");
   delay(10000);
 Serial.print("IP number assigned by DHCP is ");
 Serial.println(Ethernet.localIP());
 Udp.begin(localPort);
 Serial.println("waiting for sync");
 setSyncProvider(getNtpTime);
time_t prevDisplay = 0; // when the digital clock was displayed
{Â
 if (timeStatus() != timeNotSet) {
  if (now() != prevDisplay) { //update the display only if time has changed
   prevDisplay = now();
   digitalClockDisplay();Â
void digitalClockDisplay(){
 // digital clock display of the time
 Serial.print(hour());
 printDigits(minute());
 printDigits(second());
 Serial.print(" ");
 Serial.print(day());
 Serial.print(" ");
 Serial.print(month());
 Serial.print(" ");
 Serial.print(year());
void printDigits(int digits){
 // utility for digital clock display: prints preceding colon and leading 0
 Serial.print(":");
 if(digits < 10)
  Serial.print('0');
 Serial.print(digits);
/*-------- NTP code ----------*/
const int NTP_PACKET_SIZE = 48; // NTP time is in the first 48 bytes of message
byte packetBuffer[NTP_PACKET_SIZE]; //buffer to hold incoming & outgoing packets
time_t getNtpTime()
 while (Udp.parsePacket() > 0) ; // discard any previously received packets
 Serial.println("Transmit NTP Request");
 sendNTPpacket(timeServer);
 uint32_t beginWait = millis();
 while (millis() - beginWait < 1500) {
  int size = Udp.parsePacket();
  if (size >= NTP_PACKET_SIZE) {
   Serial.println("Receive NTP Response");
   Udp.read(packetBuffer, NTP_PACKET_SIZE); // read packet into the buffer
   unsigned long secsSince1900;
   // convert four bytes starting at location 40 to a long integer
   secsSince1900 = (unsigned long)packetBuffer[40] << 24;
   secsSince1900 |= (unsigned long)packetBuffer[41] << 16;
   secsSince1900 |= (unsigned long)packetBuffer[42] << 8;
   secsSince1900 |= (unsigned long)packetBuffer[43];
   return secsSince1900 - 2208988800UL + timeZone * SECS_PER_HOUR;
 Serial.println("No NTP Response :-(");
 return 0; // return 0 if unable to get the time
// send an NTP request to the time server at the given address
void sendNTPpacket(IPAddress &address)
 // set all bytes in the buffer to 0
 memset(packetBuffer, 0, NTP_PACKET_SIZE);
 // Initialize values needed to form NTP request
 // (see URL above for details on the packets)
 packetBuffer[0] = 0b11100011; // LI, Version, Mode
 packetBuffer[1] = 0;  // Stratum, or type of clock
 packetBuffer[2] = 6;  // Polling Interval
 packetBuffer[3] = 0xEC; // Peer Clock Precision
 // 8 bytes of zero for Root Delay & Root Dispersion
 packetBuffer[12] = 49;
 packetBuffer[13] = 0x4E;
 packetBuffer[14] = 49;
 packetBuffer[15] = 52;
 // all NTP fields have been given values, now
 // you can send a packet requesting a timestamp:       Â
 Udp.beginPacket(address, 123); //NTP requests are to port 123
 Udp.write(packetBuffer, NTP_PACKET_SIZE);
 Udp.endPacket();
My problem is, the code is unable to receive NTP response.
Can you help me what's wrong in this code?
Thank you in advance.
