NTP
So I have most likly been looking at this too long myself and just missing something painfully obvious. So I will reach out to the community for help. Below you will see my code. I swear if I take the same NTP bit of the code out, and do serial prints like the example, it works great, but then I can't get it in the web form because it says the stuff isn't defined in that scope, however, if I put it in the section where it is in the example, it says "'sendNTPpacket' was not declared in this scope" so I don't what I'm missing and would be super happy if someone could help.
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <Udp.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP085.h>
#include <Time.h>
Adafruit_BMP085 bmp = Adafruit_BMP085(10085);
void displaySensorDetails(void)
  sensor_t sensor;
  bmp.getSensor(&sensor);
  Serial.println("------------------------------------");
  Serial.print  ("Sensor:       "); Serial.println(sensor.name);
  Serial.print  ("Driver Ver:   "); Serial.println(sensor.version);
  Serial.print  ("Unique ID:    "); Serial.println(sensor.sensor_id);
  Serial.print  ("Max Value:    "); Serial.print(sensor.max_value); Serial.println(" hPa");
  Serial.print  ("Min Value:    "); Serial.print(sensor.min_value); Serial.println(" hPa");
  Serial.print  ("Resolution:   "); Serial.print(sensor.resolution); Serial.println(" hPa");
  Serial.println("");
const int VAL_PROBE = 0;
const int MOISTURE_LEVEL = 250;
int LDR_Pin = A1;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0x03 };
IPAddress ip(192,168,137,123);
unsigned int localPort = 8888;
IPAddress timeServer(132, 163, 4, 101);
const int NTP_PACKET_SIZE= 48;
byte packetBuffer [ NTP_PACKET_SIZE ];
EthernetUDP Udp;
EthernetServer server(80);
void setup(void)
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  Udp.begin(localPort);
  Serial.println("Pressure Sensor Test"); Serial.println("");
  /* Initialise the sensor */
  if(!bmp.begin())
    /* There was a problem detecting the BMP085 ... check your connections */
    Serial.print("Ooops, no BMP085 detected ... Check your wiring or I2C ADDR!");
    while(1);
  /* Display some basic information on this sensor */
  displaySensorDetails();
void loop(void)
    /* My NTP Crap */
  sendNTPpacket(timeServer);
  if ( Udp.parsePacket() ) {
    Udp.read(packetBuffer,NTP_PACKET_SIZE);
    unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
    unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
    unsigned long secsSince1900 = highWord << 16 | lowWord;
    const unsigned long seventyYears = 2208988800UL;
    unsigned long epoch = secsSince1900 - seventyYears;
unsigned long sendNTPpacket(IPAddress& address)
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  packetBuffer[0] = 0b11100011;
  packetBuffer[1] = 0;
  packetBuffer[2] = 6;
  packetBuffer[3] = 0xEC;
  packetBuffer[12]  = 49;
  packetBuffer[13]  = 0x4E;
  packetBuffer[14]  = 49;
  packetBuffer[15]  = 52;
  Udp.beginPacket(address, 123); //NTP requests are to port 123
  Udp.write(packetBuffer,NTP_PACKET_SIZE);
  Udp.endPacket();
/* End my NTP crap */
  // listen for incoming clients
  if (client) {
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println();
          client.println("<meta http-equiv=refresh content=3>");
          // read in the temperature
          int moisture = analogRead(VAL_PROBE);
          int LDRReading = analogRead(LDR_Pin);
          sensors_event_t event;
          bmp.getEvent(&event);
          float temperature;
          bmp.getTemperature(&temperature);
          float tempfa;
          int tempf = (temperature * 9.0 / 5.0 +32);
          client.println("<table>");
          client.println("<tr>");
          client.print("<td>");
              Client.print((epoch  % 86400L) / 3600);
              Client.print(':');
                if ( ((epoch % 3600) / 60) < 10 ) {
                // In the first 10 minutes of each hour, we'll want a leading '0'
                Client.print('0');
              Client.print((epoch  % 3600) / 60); // print the minute (3600 equals secs per minute)
              Client.print(':');
                if ( (epoch % 60) < 10 ) {
                // In the first 10 seconds of each minute, we'll want a leading '0'
                Client.print('0');
              Client.println(epoch %60); // print the second
          client.print("</td");
          client.print("Pressure:  ");
          client.print("</td>");
          client.print(event.pressure);
          client.print("</td><td>");
          client.print(" hPa");
          client.print("</td></tr>");
          client.print("<tr>");
          client.print("Temperature: ");
          client.print(tempf);
          client.print(" degrees");
          client.println("</td></tr>");
          client.println("<tr><td>");
          client.print("Moisture Level: ");
          client.println("</td><td>");
          client.print(moisture);
          client.println("</td><td></td></tr>");
          client.print("Light Level: ");
          client.print(LDRReading);
          client.println("</table>");
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
You have the sendNTP Packet() function defined inside another function. That is not allowed. Using Tools + Auto Format to fix your random indenting would show that.
