NTPClient not returning current time when esp32 host server on static ip
Guys i am currently working on project which requires to host esp32 on static ip and it needs to perform task when set time is reached to get time i am using ntpclient "pool.ntp.org" but it dose not return correct time
#include <Wire.h>
#include <WiFi.h>
#include <NTPClient.h>
#include <WiFiUdp.h>
#include <AsyncTCP.h>
#include <ESPAsyncWebServer.h>
const char* ssid = "ssid";
const char* password = "password";
IPAddress staticIP(192, 168, x, x);
IPAddress gateway(192, 168, x, x);
IPAddress subnet(255, 255, x, x);
AsyncWebServer server(80);
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP,"pool.ntp.org");
int t1start;
int t2start;
int t3start;
int t4start;
int t1duration = 2; // 10s
int t2duration = 10;
int t3duration = 10; // 10s
int receivedHour;
int receivedMinute;
bool executed1 = false;
bool executed2 = false;
bool executed3 = false;
bool executed4 = false;
bool executed5 = false;
  delay(3000);
  WiFi.config(staticIP, gateway, subnet, subnet);
  WiFi.begin(ssid, password);
    Serial.println("Connecting to WiFi...");
  server.on("/", HTTP_GET, [](AsyncWebServerRequest *request) {
    request->send(200, "text/plain", "Hello from ESP32!");
  server.on("/index.html", HTTP_GET, [](AsyncWebServerRequest *request) {
    request->send(200, "text/plain", "Hello from index.html!");
  server.on("/time", HTTP_GET, [](AsyncWebServerRequest *request) {
    if (request->hasParam("hour") && request->hasParam("minute")) {
      String hour = request->getParam("hour")->value();
      String minute = request->getParam("minute")->value();
      // Convert hour and minute to integers if needed
      receivedHour = hour.toInt();
      receivedMinute = minute.toInt();
      // Process received hour and minute here
      Serial.print("Received Hour: ");
      Serial.println(receivedHour);
      Serial.print("Received Minute: ");
      Serial.println(receivedMinute);
      request->send(200, "text/plain", "Time received successfully");
      request->send(400, "text/plain", "Invalid request");
  DefaultHeaders::Instance().addHeader("Access-Control-Allow-Origin", "*");
  server.begin();
  timeClient.begin();
  timeClient.setTimeOffset(19800); // Indian Standard Time (GMT +5:30)
int convert(int hour, int min, int sec)
  return hour * 3600 + min * 60 + sec; // Calculate total seconds
  timeClient.update();
  delay(200);
  int currentHour = timeClient.getHours();
  int currentMinute = timeClient.getMinutes();
  int currentSecond = timeClient.getSeconds();
  Serial.print(currentHour); // Print current hour
  Serial.print(":"); // Separator
  Serial.println(currentMinute); // Print current minute
  int currentTime = convert(currentHour, currentMinute, currentSecond);
  Serial.println(currentTime); // Print current time in seconds
  if (currentHour == receivedHour && currentMinute == receivedMinute && currentMinute <= 5 && !executed1) {
    startT1();
    startR1();
    t1start = currentTime;
    executed1 = true;
  if ((currentTime - t1start >= t1duration) && executed1 && !executed2) {
    stopT1();
    stopR1();
    startT2();
    t2start = currentTime;
    executed2 = true;
I raised similar topic for esp8266 here is the link for that topic
and here I just can give a similar answer:
remove the external NTP library.
NTP on the ESP comes with the ESP Platform Packet - no need for an external NTP library.
See my page:
hare is the updated code according to your doc but it is still not working am i doing something wrong
#ifndef STASSID
#define STASSID "ssid"          // set your SSID
#define STAPSK "pass"       // set your wifi password
#endif
/* Configuration of NTP */
// choose the best fitting NTP server pool for your country
#define MY_NTP_SERVER "in.pool.ntp.org"
// choose your time zone from this list
// https://github.com/nayarsystems/posix_tz_db/blob/master/zones.csv
#define MY_TZ "IST-5:30"
/* Necessary Includes */
#ifdef ARDUINO_ARCH_ESP32
#include <WiFi.h>                     // we need wifi to get internet access
#endif
#ifdef ARDUINO_ARCH_ESP8266
#include <ESP8266WiFi.h>
#endif
#include <time.h>
#include <Wire.h>
#include <ESPAsyncWebServer.h>            // for time() ctime()
/* Globals */
time_t now;                          // this are the seconds since Epoch (1970) - UTC
tm tm;                             // the structure tm holds time information in a more convenient way *
int t1start;
int t2start;
int t3start;
int t4start;
int receivedHour;
int receivedMinute;
  Serial.println("\nNTP TZ DST - bare minimum");
  // ESP32 seems to be a little more complex:
  configTime(0, 0, MY_NTP_SERVER);  // 0, 0 because we will use TZ in the next line
  setenv("TZ", MY_TZ, 1);            // Set environment variable with your time zone
  tzset();
  #else
  // ESP8266
  configTime(MY_TZ, MY_NTP_SERVER);    // --> for the ESP8266 only
  #endif
  // start network
  WiFi.persistent(false);
  WiFi.mode(WIFI_STA);
  WiFi.begin(STASSID, STAPSK);
    delay(200);
    Serial.print ( "." );
  Serial.println("\nWiFi connected");
  server.begin();
  time(&now); // read the current time
  localtime_r(&now, &tm);             // update the structure tm with the current time
  Serial.print("\thour:");
  Serial.print(tm.tm_hour);           // hours since midnight 0-23
  Serial.print("\tmin:");
  Serial.print(tm.tm_min);            // minutes after the hour 0-59
  Serial.print("\tsec:");
  Serial.print(tm.tm_sec);
  if (tm.tm_isdst == 1)               // Daylight Saving Time flag
    Serial.print("\tDST");
    Serial.print("\tstandard");
  int currentHour = tm.tm_hour;
  int currentMinute =tm.tm_min;
  int currentSecond = tm.tm_sec;
    startT1();
    startR1();
    t1start = convert(currentHour, currentMinute, currentSecond);
    executed1 = true;
    stopT1();
    stopR1();
    startT2();
    t2start = convert(currentHour, currentMinute, currentSecond);
    executed2 = true;
  if ((currentTime - t2start >= t2duration) && executed1 && executed2 && !executed3) {
    stopT2();
    startR2();
    startT3();
    t3start = convert(currentHour, currentMinute, currentSecond);
    executed3 = true;
  if ((currentTime - t3start >= t3duration) && executed1 && executed2 && executed3 && !executed4) {
    stopT3();
    stopR2();
    t4start = convert(currentHour, currentMinute, currentSecond);
    executed4 = true;
  delay(1000); // dirty delay
void startR1() {
  Serial.println("R1 start");
void startT1() {
  Serial.println("T1 start");
void stopR1() {
  Serial.println("R1 stop");
void stopT1() {
  Serial.println("T1 stop");
void startR2() {
  Serial.println("R2 start");
void startT2() {
  Serial.println("T2 start");
void stopR2() {
  Serial.println("R2 stop");
void stopT2() {
  Serial.println("T2 stop");
void startT3() {
  Serial.println("T3 start");
void stopT3() {
  Serial.println("T3 stop");
last time it was a wifi config problem related to this line of code
last time I showed you already how to make that line correct.
WiFi.config(ip, dns, gateway, subnet);
Why do you want to hand over the subnet two times?
set the dns and the gateway to your routers ip and it will work.
