Hi, i have problem with my combined code for pH sensor and turbidity sensor.
here is my ph sensor code
# This sample code is used to test the pH meter V1.0.
# Editor : YouYou
# Ver : 1.0
# Product: analog pH meter
# SKU : SEN0161
#define SensorPin A0 //pH meter Analog output to Arduino Analog Input 0
#define Offset 0.00 //deviation compensate
#define LED 13
#define samplingInterval 20
#define printInterval 800
#define ArrayLenth 40 //times of collection
int pHArray[ArrayLenth]; //Store the average value of the sensor feedback
int pHArrayIndex=0;
void setup(void)
pinMode(LED,OUTPUT);
Serial.println("pH meter experiment!"); //Test the serial monitor
void loop(void)
static unsigned long samplingTime = millis();
static unsigned long printTime = millis();
static float pHValue,voltage;
if(millis()-samplingTime > samplingInterval)
pHArray[pHArrayIndex++]=analogRead(SensorPin);
if(pHArrayIndex==ArrayLenth)pHArrayIndex=0;
voltage = avergearray(pHArray, ArrayLenth)*5.0/1024;
pHValue = 3.5*voltage+Offset;
samplingTime=millis();
if(millis() - printTime > printInterval) //Every 800 milliseconds, print a numerical, convert the state of the LED indicator
Serial.print("Voltage:");
Serial.print(voltage,2);
Serial.print(" pH value: ");
Serial.println(pHValue,2);
digitalWrite(LED,digitalRead(LED)^1);
printTime=millis();
double avergearray(int* arr, int number){
int i;
int max,min;
double avg;
long amount=0;
if(number<=0){
Serial.println("Error number for the array to avraging!/n");
return 0;
if(number<5){ //less than 5, calculated directly statistics
for(i=0;i<number;i++){
amount+=arr[i];
avg = amount/number;
return avg;
}else{
if(arr[0]<arr[1]){
min = arr[0];max=arr[1];
else{
min=arr[1];max=arr[0];
for(i=2;i<number;i++){
if(arr[i]<min){
amount+=min; //arr<min
min=arr[i];
}else {
if(arr[i]>max){
amount+=max; //arr>max
max=arr[i];
}else{
amount+=arr[i]; //min<=arr<=max
}//if
}//for
avg = (double)amount/(number-2);
}//if
return avg;
here is my turbidity code
Serial.begin(9600); //Baud rate: 9600
int sensorValue = analogRead(A0);// read the input on analog pin 0:
float NTU = sensorValue * (250 / 1024.0); // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
NTU = map (NTU, 0,250,250,0);
Serial.println(NTU); // print out the value you read:
and here is my combined code
#define LED 13
int pHArrayIndex=0;
void setup(void)
void loop(void)
printTime=millis();
int i;
int max,min;
double avg;
long amount=0;
if(number<=0){
return 0;
amount+=arr[i];
return avg;
}else{
if(arr[0]<arr[1]){
else{
if(arr[i]<min){
min=arr[i];
}else {
if(arr[i]>max){
max=arr[i];
}else{
}//if
}//for
}//if
return avg;
int sensorValue = analogRead(A1);// read the input on analog pin 0:
and the error message that popped out is 'NTU' does not name a type.
