Number Input, Calculator Style
Hey guys, first time post, frequent researcher for my project.
I've got a 4D Systems uLCD-43PT and an Arduino Due.
I have a custom keypad on it with 3 LED displays on it (0,1,2).
I'm surprised I'm having to ask this but I can't find it anywhere on the internet in the past several hours:
How do I take the numbers being typed in and put them in order in the LED display (just using #0 right now). I can get the numbers from the keys to the display, but how would I make it so that I could type in, say, 1,325?
Do i take each button press, put them into different variables, and then do the math to sort them into the right order? I've seen some calculators on touch screen displays but I never get any code to see how it works.
Thanks for any help guys.
This might help.
#include <Keypad.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x20,20,4);
long first = 0;
long second = 0;
long total = 0;
double Ftotal = 0;
char customKey;
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
    '1','2','3','+'}
    '4','5','6','-'}
    '7','8','9','*'}
    'C','0','=','/'}
byte rowPins[ROWS] = {
  2,3,4,5}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {
  11,10,9,8}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS);
void setup(){
  lcd.init();                      // initialize the lcd
  lcd.backlight();
void loop(){
  customKey = customKeypad.getKey();
  switch(customKey)
  case '0' ... '9': // This keeps collecting the first value until a operator is pressed "+-*/"
    lcd.setCursor(0,0);
    first = (first * 10) + (customKey - '0'); // This method is how you combine all the key presses into one value.
    // (customKey - '0') -> converts the keypad character to integer
    lcd.print(first);
  case '+':
    lcd.setCursor(0,1);
    lcd.print("+");
    second = SecondNumber(); // get the collected the second number
    total = first + second;
    lcd.setCursor(0,3);
    lcd.print(total);
    first = 0, second = 0; // reset values back to zero for next use
  case '-':
    lcd.setCursor(0,1);
    lcd.print("-");
    total = first - second;
    lcd.setCursor(0,3);
    lcd.print(total);
  case '*':
    lcd.setCursor(0,1);
    lcd.print("*");
    total = first * second;
    lcd.setCursor(0,3);
    lcd.print(total);
  case '/':
    lcd.setCursor(0,1);
    lcd.print("/");
    lcd.setCursor(0,3);
    second == 0 ?
      lcd.print("Invalid")
      Ftotal = (float)first / (float)second;
    lcd.print(Ftotal);
  case 'C':
    lcd.clear();
long SecondNumber(){
  while( 1 )
    if(customKey >= '0' && customKey <= '9')
      second = (second * 10) + (customKey - '0');
      lcd.setCursor(0,2);
      lcd.print(second);
    if(customKey == '=') break;  //return second;
 return second;
modified and works beautifully. thanks!
Did you learn from it or just modify it?
