So I am trying to understand bytes and serial communication and I have posted about Wireless communication before and received some help from that. I am using EasyTransfer to send sensor data from one arduino to another with xbee shields. I was reading up on Easy transfer and it says in the readme that the Struct size may not pass 255 bytes.
So my question (which might sound dumb) is if I combined multiple sensors into one array i.e (Button data, button data 2, potentiometer data,...etc) will that exceed more the 255 bytes. I have mapped them so the reading is smaller than 255?
The size of the structure or array you have will be determined by the type and number of variables. A byte or char is one byte, an int two bytes, a long or float 4 bytes. It sounds like you have mapped all your individual data items to fit into a byte, but that is probably not necessary.
You can use the Sizeof() operator to let the compiler figure out the number of bytes in the data structure. If I understand your protocol correctly the Sizeof(myData) needs to be less than 255.
http://arduino.cc/en/Reference/Sizeof
Motorscooter: cattledog's given you the right answer, but note that the sizeof() operator is used with a lowercase 's'.
