hello all!!
i want to know how many machine cycles used to store a data in memory(Stack and EEPROM) ??
thank you.
hello all!!
thank you.
you can use objdump.exe to see the assembly output. It is part of the toolchain.
Thank you Rob Tillaart.!!
currently i am running below example code.
#include <EEPROM.h>
// the current address in the EEPROM (i.e. which byte
// we're going to write to next)
int addr = 0;
int val = 0;
EEPROM.write(addr, val);
val ++;
addr = addr + 1;
if (addr == 512){
addr = 0;
val = 0;
delay(100);
objdump commad is:
C:\Users\bijendra\AppData\Local\Temp\build6162742129533870816.tmp>C:\Users\bijendra
h\Downloads\arduino-1.0.5-windows\arduino-1.0.5\hardware\tools\avr\bin\avr-objdu
mp.exe -D -S eeprom_write.cpp.elf > bijendra3.txt
i got a Disassembly output of EEPROM write is
static inline void eeprom_write_byte (uint8_t *__p, uint8_t __value)
do {} while (!eeprom_is_ready ());
104: f9 99 sbic 0x1f, 1 ; 31
106: fe cf rjmp .-4 ; 0x104 <_ZN11EEPROMClass5writeEih>#if defined(EEPM0) && defined(EEPM1)
EECR = 0; /* Set programming mode: erase and write. */
108: 1f ba out 0x1f, r1 ; 31
#endif#if E2END <= 0xFF
EEARL = (unsigned)__p;
#else
EEAR = (unsigned)__p;
10a: 72 bd out 0x22, r23 ; 34
10c: 61 bd out 0x21, r22 ; 33
#endif
EEDR = __value;
10e: 40 bd out 0x20, r20 ; 32
: [__eecr] "i" (_SFR_IO_ADDR(EECR)),
[__sreg] "i" (_SFR_IO_ADDR(SREG)),
[__eemwe] "i" (EEMWE),
[__eewe] "i" (EEWE)
: "r0"
110: 0f b6 in r0, 0x3f ; 63
112: f8 94 cli
114: fa 9a sbi 0x1f, 2 ; 31
116: f9 9a sbi 0x1f, 1 ; 31
118: 0f be out 0x3f, r0 ; 63
so the total number of cycles consumed(command written in blue color) is
1+1+1+1+2+2+1
am i right or i am making any mistake??
