Hi
I'm trying to build arduino based rotary table using Nextion Display and 4x4matrix keypad.
I use external keypad because it's much better to operate with.
But i ran into problem when trying to input data.
Let's say i want to input number "456" to nextion display text input field. When i send 4 it will display 4 and when i send 5 it will delete 4 and display 5 etc.
Then i thought that maybe i could use similar approach as nextion button keypad code uses. Basically "textfield=textfield"+some_number". But it's doesn't seem to work when this command is sent to nextion via serial.
Serial2.print(F("t15.txt="));
Serial2.print(F("\"t15.txt+\""));
Serial2.print(key);
Serial2.print(F("\""));
Serial2.write(0xff);
Anyone have any ideas how to solve this problem?
