Numbers in Print function
Hi to all friends
I would like to ask a question about printing numbers in my screen or in my serial monitor
lets say that i have a potentiometer that gives me results from ''500'' until ''7000'' with map function
so i can take lot of variable numbers... like 522, 545, 1123, 1476 etc
is any formula or special code that i could use in order to print these numbers as a ''hundreds'' (can't remember the right word in english)
lets say that if i am getting result ''534'' the serial print would be ''500''
756 to 700
1345 to 1300
etc..
thanks in advance
You should set out your requirements exactly. Example: 700 thru 799 >>>——-> 700 ? 1300 thru 1399 >>>——-> 1300 ?
That's not a programming question. That's just math.
int i = 543;
int trimmed =  i - (i %100);
Serial.print(trimmed);   // prints 500
Thanks for the reply :slight_smile:
i am using the code below to print the results from the variable ‘‘rpm’’
#include "U8glib.h"
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NO_ACK);  // Display which does not send AC
float value = 0;
float rev = 0;
int rpm;
int oldtime = 0;
int time;
void isr() //interrupt service routine
  rev++;
  // assign default color value
  if (u8g.getMode() == U8G_MODE_R3G3B2)
    u8g.setColorIndex(255);     // white
  else if (u8g.getMode() == U8G_MODE_GRAY2BIT)
    u8g.setColorIndex(3);         // max intensity
  else if (u8g.getMode() == U8G_MODE_BW)
    u8g.setColorIndex(1);         // pixel on
  else if (u8g.getMode() == U8G_MODE_HICOLOR)
    u8g.setHiColorByRGB(255, 255, 255);
  attachInterrupt(0, isr, RISING); //attaching the interrupt
  delay(100);
  detachInterrupt(0);           //detaches the interrupt
  time = millis() - oldtime;    //finds the time
  rpm = (rev / time) * 60000 / 2; //calculates rpm
  oldtime = millis();           //saves the current time
  rev = 0;
  Serial.println(rpm, DEC);
  //lcd.print(" RPM");
  u8g.firstPage();
  do {
    Rpms();   //mpainei to onoma tou void me to display
  } while ( u8g.nextPage() );
//////////////////////////////////////////////RPM//////////////////////////////
void Rpms(void) {
  u8g.setFont(u8g_font_fub11);
  u8g.setFontRefHeightExtendedText();
  u8g.setDefaultForegroundColor();
  u8g.setFontPosTop();
  u8g.drawStr(4, 20, "RPM");
  u8g.setPrintPos(70, 20);
  u8g.print(rpm);
  //delay(200);
so i cant do that with just a simple line code…
i have to use the ‘’ if ‘’ statement ?
example :
  if (rpm >= 500 || rpm <= 599 ) {
    Serial.println("500")
  else if (rpm >= 600 || rpm <= 699 ) {
    Serial.println("600")
  else if (rpm >= 700 || rpm <= 799 ) {
    Serial.println("700")
  else if (rpm >= 800 || rpm <= 899 ) {
    Serial.println("800")
Right ?
Did you try Delta_G’s example ?
Ask yourself; what will happen?
What does && do?
Delta_G: That's not a programming question. That's just math.
int i = 543;
Thanks ... i am still new in coding.. and lot of times i need a guide to take the right path :) but with practice i am starting to learn from my mistakes
Thank you both for the replies :)
Yes i tried what ''Delta_G'' suggested , and worked fine :)
Thanks again :)
