Numerically Controlled Oscillator (NCO)
I have finished an application note for a four channel numerically controlled oscillator (NCO). The documentation, library and sketch are at http://tinyurl.com/ydmz2su
The code runs on the Arduino compatible Wiblocks NB1A which has an 168P/328P and a TI TLV5620 four channel DAC. A timer interrupt is used to trigger periodic updates of the DAC channels.
The code documentation is sparse but I believe that the application note is complete. I document how the phase accumulator works and the relationship between the phase increment and frequency. I did not go into the details of the SNR calculations. The two references I used are listed at the bottom of the webpage.
Also, I just prototyped an NB1A MIDI interface that includes a midi-in, midi-out and four two-pole filters. The filters connect to the DAC outputs to smooth the stair-steps of the NCO.
(* jcl *)
www: http://www.wiblocks.com twitter: http://twitter.com/wiblocks blog: http://luciani.org
Nice project.
Just one question:
  if (nco_round(i)) {
    addr += 1;
    addr &= NCO_ADDR_MASK;
Why not just add in the rounding bit?
The conditional is redundant surely?
If it’s a 1, it’ll round; if it’s a zero, it won’t.
Maybe squeeze a little more range out of it?
I believe I was originally worried about how the bit-fields in the phase accumulator structure would work with the wavetable address byte. Testing for a true value of the bit-field and then adding one to the addr byte seemed safer.
I believe you are correct that
addr += acc.acc_bits.round
will work. I just need to take a look at the asssembler output to verify it.
Thanks for the feedback.
(* jcl *)
On a second look, the bitwise-AND is redundant too, I think.
The and is necessary for this example. Only the lower six bits represent a valid address. Adding one to a value of 0x3F produces an invalid address.
When the 6bit bitfield is assigned to a byte it is right-justified.
(* jcl *)
P.S. I learned this bit-field lesson the hardway ;)
Ah! Yes - I used to use an eight bit phase accumulator (different processor, different architecture), so the AND was never necessary. Sorry!
Thanks for taking that close a look at the code!
(* jcl *)
I prefer to have a bigger table and keep all the conditional code out of the inner loop. My NCO code can be found here for reference: http://adrianfreed.com/content/arduino-sketch-high-frequency-precision-sine-wave-tone-sound-synthesis
It has the interpolation code you need to smoothly ramp frequency and amplitude if you want to make clean music synthesizer out of this idea. I also include the tables to map midi note numbers into phase increment values.
