Nunchuck Program Not Working
I’ve built a balancing robot as shown in this link: YABR Balancing Robot . The robot balances quite will based on the provided Arduino sketch. However the provided Arduino hardware test sketch does not show the nunchuck readings. I found a sketch online that did confirm that the nunchuck did work.
When the hardware test sketch is run on an Uno the only text on the serial monitor is
Scanus…
Scanning I2C bus…
I tried to highlight the portion of the code that pertains to the nunchuck in red, but it didn’t work. If you look for the text “color=red”, that is where it begins.
Any suggestions to get the nunchuck working?
Chuck
//Terms of use
//THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
//IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
//FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
//AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
//LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
//OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
//THE SOFTWARE.
#include <Wire.h>
byte error, MPU_6050_found, nunchuck_found, lowByte, highByte;
int address;
int nDevices;
  Wire.begin();
  TWBR = 12;
  Serial.println("Scanning I2C bus...");
  nDevices = 0;
  for(address = 1; address < 127; address++ )
    Wire.beginTransmission(address);
    error = Wire.endTransmission();
    if (error == 0)
      Serial.print("I2C device found at address 0x");
      if (address<16)Serial.print("0");
      Serial.println(address,HEX);
      nDevices++;
      if(address == 0x68 || address == 0x69){
        Serial.println("This could be a MPU-6050");
        Wire.write(0x75);
        Serial.println("Send Who am I request...");
        Wire.requestFrom(address, 1);
        while(Wire.available() < 1);
        lowByte = Wire.read();
        if(lowByte == 0x68){
          Serial.print("Who Am I responce is ok: 0x");
          Serial.println(lowByte, HEX);
        else{
          Serial.print("Wrong Who Am I responce: 0x");
          if (lowByte<16)Serial.print("0");
        if(lowByte == 0x68 && address == 0x68){
          MPU_6050_found = 1;
          Serial.println("Starting Gyro....");
          set_gyro_registers();
     [color=red] if(address == 0x52){
        Serial.println("This could be a Nunchuck");
        Serial.println("Trying to initialise the device...");
        Wire.beginTransmission(0x52);
        Wire.write(0xF0);
        Wire.write(0x55);
        delay(20);
        Wire.write(0xFB);
        Wire.write(0x00);
        delay(20);
        Serial.println("Sending joystick data request...");
        Wire.write(0x00);
        Wire.requestFrom(0x52,1);
        if(lowByte > 100 && lowByte < 160){
          Serial.print("Data response normal: ");
          Serial.println(lowByte);
          nunchuck_found = 1;
        else{
          Serial.print("Data response is not normal: ");
          Serial.println(lowByte);[/color]
    else if (error==4)
      Serial.print("Unknown error at address 0x");
      if (address<16)
        Serial.print("0");
  if (nDevices == 0)
    Serial.println("No I2C devices found\n");
    Serial.println("done\n");
  if(MPU_6050_found){
    Serial.print("Balance value: ");
    Wire.beginTransmission(0x68);
    Wire.write(0x3F);
    Wire.requestFrom(0x68,2);
    Serial.println((Wire.read()<<8|Wire.read())*-1);
    delay(20);
    Serial.println("Printing raw gyro values");
    for(address = 0; address < 20; address++ ){
      Wire.write(0x43);
      Wire.requestFrom(0x68,6);
      while(Wire.available() < 6);
      Serial.print("Gyro X = ");
      Serial.print(Wire.read()<<8|Wire.read());
      Serial.print(" Gyro Y = ");
      Serial.print(" Gyro Z = ");
      Serial.println(Wire.read()<<8|Wire.read());
    Serial.println("");
  else Serial.println("No MPU-6050 device found at address 0x68");
  [color=red]if(nunchuck_found){
    Serial.println("Printing raw Nunchuck values");
      Wire.write(0x00);
      Wire.requestFrom(0x52,2);
      while(Wire.available() < 2);
      Serial.print("Joystick X = ");
      Serial.print(Wire.read());
      Serial.print(" Joystick y = ");
      Serial.println(Wire.read());
      delay(100);
  else Serial.println("No Nunchuck device found at address 0x52");
  while(1);
[/color]
void set_gyro_registers(){
  //Setup the MPU-6050
  Wire.beginTransmission(0x68);                                     //Start communication with the address found during search.
  Wire.write(0x6B);                                                         //We want to write to the PWR_MGMT_1 register (6B hex)
  Wire.write(0x00);                                                         //Set the register bits as 00000000 to activate the gyro
  Wire.endTransmission();                                                   //End the transmission with the gyro.
  Wire.write(0x1B);                                                         //We want to write to the GYRO_CONFIG register (1B hex)
  Wire.write(0x00);                                                         //Set the register bits as 00000000 (250dps full scale)
  Wire.write(0x1C);                                                         //We want to write to the ACCEL_CONFIG register (1A hex)
  Wire.write(0x08);                                                         //Set the register bits as 00001000 (+/- 4g full scale range)
  Wire.write(0x1A);                                                         //We want to write to the CONFIG register (1A hex)
  Wire.write(0x03);                                                         //Set the register bits as 00000011 (Set Digital Low Pass Filter to ~43Hz)
Sorry, but you didn't actually say what didn't work or did work, can we get some detail there? In other words, what did the code not do, that it was supposed to do?
aarg,
Thanks for the reply. The code is suppose to give position readouts for the nunchuck as it is moved. All that happens is the serial monitor prints this once and just hangs there.
Scanus...
Scanning I2C bus...
Chuck
This
  while(1);
is going to cause a hang. It gets executed no matter what happens with the if...else.
Perhaps you intended (untested)
     while(1);
Well that seems to have nothing to do with the section in red, which comes after the i2c bus scan that fails. Are you saying that the i2c bus devices work with a different sketch?
Chuck,
I'm sorry I don't know the answer to your question but I am curious to know what a nunchuck is in this context. I asked my friend Mr Google and he seems to think they are weapons used in martial arts, no mention of their use in electronics or robots. Do please explain.
Thanks.
It's a hand controller for a Wii. Do a search on Amazon for a nunchuck.
Thank you Chuck, I had not the slightest idea. :o
